generator "f" control
Old Jan 9, 2004 | 02:56 AM
dansel's Avatar
Smile generator "f" control
recently had a code p0622 generator field "f" control circuit malfuntion. i have co problems with batts being charged or any other problems that i notice. it also said not switching over. can anyone tell me what the "f" circuit is & what its funcion is. would appreciate any & all comments in that im not all that bright when it comes to the chargeing system. i am capable of takeing the gen. or alt apart & repairing if i knew what the problem is.( i thought we had alternaters but the code said generator) thx don
Old Jan 9, 2004 | 09:55 AM
kandgo's Avatar
On the back side of your alterator,there is 5 nuts holding the wire harness,ASD relay output,Gen Field Driver,ground wire and positive wire,on the back of the alt, starting at the bottom count up, the first just holds the harnes, the second one which goes thru a terminal is the Gen. Field Driver. the third is the ASD relay output,The fourth is Ground wire which is black and whit,the fith is the positive. To test your code problem start with the asd,Whith key on, probe the asd relay at the back of the alt,it should be above 10v min. if that is ok,then go the Gen Back Field,probe it, it too should be above 10v. If both are good then take the all five nuts off and take the harness completly away from alt. remember turn key off and be carefull of the hot and ground, now take your meter and check the ohm beteween the asd and gen field on the back of the alternator,it should be below 5 ohms if not the alternator needs repair{which most likley is the culprit},if it is ok then check the resistance between the Gen Field at the disconnected alter. harnes. it too should be below 5 ohms. Do this and get back with the results. Goodluck, RIck We call them alternators,dodge calls them Gen. Go figure
Old Jan 9, 2004 | 01:00 PM
dansel's Avatar
gen."f" control
kandgo thxs for a very informative reply. i will check all this out & reply as soon as i finish. don
Old Jan 9, 2004 | 09:48 PM
bama's Avatar
i dont know what it has to do with it,but on my truck when ever i take out the trans. relay and put in the jumper to wire up my lock up switch on my convertor,mine sets the same code.it sets 3 different trans. related codes,and the code youre getting also.all functioning of the alternator seems fine.i can unhook the switch,put the relay back in,clear the codes,and it wont set them again until i reinstall the switch.since the last time i installed the switch,codes are there again now,i just left it in and not had any problems for about 6 months now.i never get a light thrown but the codes are still there. any ideas on this one?
Old Jan 10, 2004 | 02:35 AM
dansel's Avatar
Smile gen.:f: control
bama im sorry to say i dont know. im getting other codes as well but i think there all caused from this "f" field im having. read kandgo reply it might help. other wise wait someone will try to answer you. don
Tardog
Mar 17, 2008 04:12 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
grizzly660fan
Jan 2, 2004 10:02 AM
TexasDiesel
Dec 27, 2002 10:47 AM
