Gauge Power
Old Feb 8, 2004 | 04:08 PM
procrastinator's Avatar
Angry Gauge Power
Its late in the afternoon and I am losing sunlight quickly.
I am installing my aftermarket gauges in the freezing cold. I have already installed the pods, and I have power with dimmer control for the background lights. What I can't not find is where to tap into the power line for the gauges. I only want the gauges on when the truck is running, but apparently Chrysler doesn't provide any type of spares in the fuse block unless I want to put a toggle switch on it and that is something I will not do.
I did a search on past articles, and I came up with a fuse tap. What is that? Apparently noone at O'reilly or Radio Shack had an idea either.
Thanks
One annoyed procrastinator
Old Feb 8, 2004 | 04:30 PM
amartinson's Avatar
Fuse taps look like this:
Make sure you put the tap on the fused side, not the hot side of the fuse block.
Old Feb 8, 2004 | 04:54 PM
dodgediesel4x4's Avatar
any one know where to get those fuse taps?
Old Feb 8, 2004 | 05:04 PM
amartinson's Avatar
Got mine at NAPA. Should be readily available.
Old Feb 8, 2004 | 05:05 PM
handymantim's Avatar
www.radioshack.com has a fuse tap for the flat blade type fuses:
http://www.radioshack.com/product.as...%5Fid=270-1204
Maybe your local Radio Shack store will know what they are if you give them their own catalog number: 270-1204 or maybe if you print out and bring in a picture.
Also, what year truck are you working on? I've got a 2004 shop manual and I'd be happy to try and find a wire that is hot when running if you want.
Old Feb 8, 2004 | 05:18 PM
billg's Avatar
I got something similar at Autozone for about $5.00.
Old Feb 8, 2004 | 08:53 PM
Thank You,
After looking at your pictures, I realized that I should have asked everyone before I opened the dash. About five minutes before Amartinson's reply came in, I found an acceptable wire lead. As I looked at the picture after the completion of today's project, I said "Huh, that would have saved me about 3-4 hours in 30* weather."
Thanks for all the help again.
A much happier procrastinator
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
