gasoline in diesel
Old Nov 10, 2008 | 03:54 PM
dcool1's Avatar
gasoline in diesel
Got up at 3:00 am to go to deer lease. Pulled into station to tank up. Everything going fine until I noticed the price per galloin was very cheap! I looked and I was pumping gasoline! I pumped about half tank of gasoline. I went home (3 miles) and syphoned out 30 gallons of crap. I then went back and put $98.00 of diesel in. I don't think I did any damage to truck.
My question is: will the gasoline and diesel separate in the storage barrel? If not, what do you do with 30 gallons of not diesel, not gasoline
Old Nov 10, 2008 | 04:12 PM
patdaly's Avatar
Shouldn't separate out.
If it were me, I would add 2 gallons per fill up for the next 15 fillups, best during the colder weather.
Old Nov 10, 2008 | 04:58 PM
rtroutman69's Avatar
You can put 2 cycle oil in the gas to increase the amount of lubrication. I'm not exactly sure of the ratio /gal but someone will chime in with it soon.
Old Nov 10, 2008 | 05:08 PM
Here's an old post that I found on a thread in the 1st gens section. (search "gasoline"). Hope it helps
On a VP pumped 2002 all you need to do is go pick up one gallon of first quality 2 cycle chainsaw oil. Use the good stuff for a Husky, Echo, or Stihl. Do not use Amsoil or any of the synthetics for this purpose, even though they are great oils.
Then pick up one gallon of ashless boat motor 2 cycle oil.
Dump both gallons into the 25 gallons of gasoline in your tank and then jump up and down on the bumper for a good 20 minutes.
The oil will mix with the gasoline and provide the needed lubricity and viscosity to allow your engine to just burn the contaminated fuel.
Then start the truck and let it idle for 3 minutes before you attempt to drive it. After the 3 minutes you can use it as you would normally, just do not go try and pull a heavy load until you get that tank of fuel burned.
The reason to use a top quality chain saw oil is that it includes two additives, a fuel conditioner, and another with a very active molecule that will continue to mix the fuel and oil mixture even after you are done jumping around swishing the tank on the truck. The reason to use an ashless outboard oil is to increase the viscosity of the fuel mix without breaking the bank. You could use two gallons of Stihl oil just as easily.
After the mixed fuel has burned down to one quarter of a tank left, just fill it with regular diesel and you will be good to go.
You will likely have to change your filter after this exercise, as the mix will pick up all sorts of crap from the tank and suspend it in the fuel for the filter to catch. Have to credit to someone who knows a whole lot more about diesels than me.
_________________________
Old Nov 10, 2008 | 05:10 PM
You won't need to do the bumper jumping thing with what you've siphoned off.
Old Nov 11, 2008 | 01:56 AM
snoyes's Avatar
Well looks like you got a good amount of fuel to help start up bonfires. I wouldn't run it through the truck again, especially after all the transferring you've done with it.
Old Nov 11, 2008 | 01:24 PM
dcool1's Avatar
Thanks to all for the replies. I don't need to start that many bonfires though
Old Nov 11, 2008 | 05:17 PM
GAmes's Avatar
Here is an experts view on gas in a diesel engine. He doesn't cover adding 2 cycle oil, but in my view the 2 cycle oil won't do much, if anything, to keep from damaging your engine. Here is why. A 2 cycle engine actually accomplishes two things per cycle while running, whereas a 4 cycle completes one task per cycle. This is possible by making use of both the combustion side and the crankcase side of the piston. Following the flow of fuel, we'll start with the engine intake from the carburetor. As the crankshaft rotates, the piston is pushed upwards. This does two things. One, the rising piston generates a vacuum in the sealed crankcase which pulls a fresh air/fuel charge from the carburetor into the crankcase (thus the reason for having to add lubricating oil to the gas for 2 cycle engines). In other words, 2 cycle oil is used to lube the rod and main bearings, not the piston rings from the top side. I think you would be better off adding more gas to the mix and pumping it into a carburated gas engine.
TDReprint
MIXING GASOLINE AND DIESEL
(Issue 26, pages 14 – 15)
My wise old mechanic who has worked on Mercedes for years told me that if I put one gallon regular gas to a diesel tankfull after about every four tanks that it would perform essentially the same job as a fuel injector cleaner at a fraction of the cost.
I would like to hear a technical opinion.
Bill Carson , e-mail
Bill, I’ll turn the answer to your request for a technical opinion over to Brian Kmetz. As a mechanical engineer, Brian’s daily task at work is to extract BTUs through oxidation from mass quantities of methane and fuel oils. Needless to say, he knows how the fuel “stuff” works. Brian writes:
We hear this one all the time. Another version is to add one gallon of gasoline to 20 gallons of diesel fuel as a cheap easy anti-gel for winter fuel. I’ll include alcohols in this discussion because a lot of guys add it instead of gasoline. Both fuels have the same detrimental effect on diesel fuel and are very close in weight and BTU content.
The mechanic meant well and probably never saw a fuel pump or injector failure due to improper blending of fuels. But that doesn’t mean one is not risking damage, even in small dosages.
Gasoline and alcohols hit diesel fuel right where it hurts the most. Those light thin fuels will lower the cetane number and lubricity. To explain how octane and cetane DO NOT work together, I’ll have to review more crude oil and fuel fundamentals.
The light distillates that gasolines are made from have a natural high-octane index. The middle distillates that diesel fuels come from have a high cetane index. The octane and cetane indexes are INVERSE scales. A fuel that has a high octane number has a low cetane number, and a high cetane fuel has a low octane number. Anything with a high octane rating will retard diesel fuel’s ability to ignite. That’s why each fuel has developed along with different types of engine designs and fuel delivery systems. Gasoline mixed in diesel fuel will inhibit combustion in a diesel engine and diesel fuel mixed in gasoline will ignite too soon in a gasoline engine.
A lot of old-time mechanics added some gasoline to diesel to supposedly clean the carbon deposits out of the cylinders. I have never read anything that said it worked. Gasoline will make the fuel burn hotter, and hotter burning fuels burn cleaner. That’s probably where the theory got started. In the older diesel engines that belched lots of black smoke even when properly tuned, the result of adding gasoline was probably more white smoke instead of black. This might lead one to believe the engine was running cleaner. Maybe so, probably not. Here’s what happens.
Gasoline will raise the combustion temperature. This might or might not reduce carbon deposits in the cylinder. This also might or might not overheat the injector nozzle enough to cause coking on the nozzle. That’s a clogged injector tip in layman’s terms. The fuel being injected is the only thing that cools the nozzle. Diesel fuel has a lower combustion temperature than gasoline. The fuel injectors depend on the fuel burning at the correct rate and temperature for a long life. If the combustion temperature is raised long enough, the gums and varnishes in gasoline will start to cook right in the fuel injector and turn into carbon. These microscopic carbon particles will abrade the nozzle. High combustion temperatures alone will shorten fuel injector life, gasoline makes the problem worse.
Gasoline and alcohols do have an anti-gel effect on diesel fuel, but these fuels are too thin and will hurt the lubricity. Alcohols work as a water dispersant in small amounts, but also attract water in large amounts. Diesel fuel is already hydrophilic (attracts water) so why add to the problem. The old timers got away with this because high sulfur diesel fuel had enough lubricity to take some thinning. Today’s low sulfur diesel fuels have adequate lubricity, but I wouldn’t put anything in the tank that would thin out the fuel, reduce lubricity, or attract water.
Opposites do not attract in this case. Use any of the diesel fuel additives available to clean out carbon deposits, not gasoline or alcohols.
While we’re on the subject of fuels, let’s discuss another common question. What is cetane?
Cetane is to diesel fuel what octane is to gasoline. It is a measure of the fuel’s ignition quality and performance. Cetane is actually a hydrocarbon chain, its real name is 1-hexadecane. It is written as C16H34, or a chain of 16 carbon atoms with 34 hydrogen atoms attached. All HC chains are also referred to as paraffins. Cetane is a hydrocarbon molecule that ignites very easily under compression, so it was assigned a rating of 100. All the hydrocarbons in diesel fuel are indexed to cetane as to how well they ignite under compression. There is very little actual cetane in diesel fuel.
All the hydrocarbons in diesel fuel have similar ignition characteristics as cetane. Cetane is abbreviated as CN. A very loose way to think about cetane is if the fuel has a CN of 45, then the fuel will ignite 45% as well as 100% cetane. Diesel engines run just fine with a CN between 45 to 50. There is no performance or emission advantage to keep raising the CN past 50. After that point the fuel’s performance hits a plateau.
Diesel at the pump can be found in two CN ranges: 40-46 for regular diesel, and 45-50 for premium. The minimum CN at the pump is supposed to be 45. The legal minimum cetane rating for #1 and #2 diesel is 40. Most diesel fuel leaves the refinery with a CN of around 42. The CN rating depends on the crude oil the fuel was refined from. It varies so much from tanker to tanker that a consistent CN rating is almost impossible. Distilling diesel is a crude process compared with making gasoline. Gasoline is more of a manufactured product with tighter standards so the octane rating is very consistent. But, the CN rating at the diesel pump can be anywhere from 42-46. That’s why there is almost never a sticker on a diesel fuel pump for CN.
Premium diesel has additives to improve CN and lubricity, detergents to clean the fuel injectors and minimize carbon deposits, water dispersant, and other additives depending on geographical and seasonal needs. More biocides added in the south in summer, more ant-gel added in the north in winter. Most retailers who sell premium diesel will have little brochures called POPs (Point of Purchase) at the counter explaining what’s in their fuel. Please don’t ask the poor clerk behind the counter any technical questions after reading this discussion. All they need to know how to do is sell you beer, milk, cigarettes, lottery tickets, and take your money.
Texaco and Amoco are two big names who sell premium diesel in limited markets. Amoco primarily sells its Premier to specialized industrial and agricultural markets. I cannot get either in my area. Most fuel retailers buy additives or buy treated fuel. In the Northern plains states, Koch is a well-known marketer of premium diesel. I buy it when I travel into Northern Wisconsin.
Because there are no legal standards for premium diesel yet, it is very hard to know if you are buying the good stuff. I have good news. An ASTM task force has drafted standards for premium diesel. When the new specifications are accepted, information will have to be posted on the fuel pump. Retailers will no longer be allowed to label cheap blended diesel as ‘premium.’ They will have separate pumps with clear labels on both informing the customer what is being sold. The marketing and labeling will be the same as with regular and premium gasoline. Retailers selling the real thing use this system now. Enforcement of all fuel standards is done at the state level in the USA.
Diesel fuel is an international commodity for industry. Therefore, you should be picky about where you fill up. Shop for price from a large volume retailer so you have the freshest fuel. That’s about the best advice I can give.
The 1994 legislation and reformulation of diesel fuel in North America is due to an international effort for lower emissions. Cleaner diesel emission laws are on the way. Diesel fuel is going to be reformulated into a cleaner fuel in general. Without getting too technical (this is over-simplified and very generalized), diesel fuel for the most part is made up of two different hydrocarbon families: paraffins and aromatics. The paraffins have a naturally high cetane index, burn clean, but cause the annoying gel problem in winter. The aromatics have a naturally high lubricity, low cetane index, and cause a lot of diesel emissions and soot. Reformulated diesel will have a higher paraffin content, higher cetane number, and a much lower aromatic and sulfur content. It will also be more prone to jelling and have a lower lubricity. Big oil is working on improved additives as I type this.
The reason nothing has happened yet is because of infighting in the EPA on its new Tier II Emissions standards for gasoline and diesel. Ultra-clean technology for gasoline and diesel engines is almost ready to go, but the refiners have to lower the sulfur level drastically in both fuels. The EPA should formally set something by year 2000.
Brian Kmetz
Old Nov 13, 2008 | 02:22 PM
robert78.5's Avatar
It would be safer to use it in a gas powered vehicle.
Old Nov 13, 2008 | 02:56 PM
BigIron70's Avatar
Cummins Guru
I would not use it in a gas motor. I have a car that was towed into dealership that had diesel in tank and it DESTROYED THE ENGINE! holes in the piston. If you put into diesel truck you could also do damage to injectors or high pressure pump from lack of lubrication. Gasolene will also detonate if compressed to high pressures like in a diesel engine. I wouldn't push my luck for a few gallons of fuel, it will cost you thousands if you use it in your truck. I would dump it into the used motor oil.
Old Nov 17, 2008 | 10:38 PM
TruckU's Avatar
I have an old diesel burning steam cleaner that doesn't care if there is a little gasoline in the mix. It actually lights better and burns cleaner with a little gas blended in. 30 gallons of 50/50 blend would clean everything on the place, and then some.
Old Nov 19, 2008 | 06:53 PM
Steve Roseman's Avatar
I don't know what kind of climate you live in. That mix would work great in a kerosene type salamander heater. If you are in a cold climate you could buy a heater or sell it cheap to someone who has a heater. I wouldn't run it in my truck or car.
sweetwaterguy
35
Dec 29, 2006 11:48 AM
rattle_rattle
Apr 7, 2005 06:24 PM
67HotRod
Mar 12, 2005 06:53 PM
tfarmer96
16
Mar 4, 2005 09:00 PM
scottsjeeprolet
Feb 15, 2005 08:32 AM
