fuel usage
Old Feb 14, 2006 | 01:00 PM
kinser5mfan's Avatar
fuel usage
just made the first out of town trip with it today. not too good!!
at 65mph the tach was reading 2200rpm and the fuel gauge moved 1\8 of a tank in 50 miles does this sound normal??? or am i looking for too much
Old Feb 14, 2006 | 01:32 PM
TonyB's Avatar
Check the crank case for oil....See if an injector is leaking
Fill the tank & check mileage/fuel used...See if you are using excessive fuel
Can't trust fuel gauges, they have a very non-linear response.
Tony
Old Feb 14, 2006 | 02:10 PM
thanks i just looked at the gauge again and it is setting more towards the full mark
the truck sat for a month and was not driven out of town for two so maybe it just needs driven awhile first before i check it
Old Feb 14, 2006 | 05:36 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The fuel needle on my '99 usually doesn't move until ~100 miles.
But I fill it to the top of the neck on fuel-ups.
Sounds like a 4.10 rear gear from the speed/RPM.
Old Feb 14, 2006 | 06:20 PM
Itsmejoe231's Avatar
What size tires do you have on your truck? I have the 4.10 gears and I am around 2100 rpm's at 70 mph.
Here is about where you want to be. http://www.dodgeram.org/tech/specs/axle/47auto.htm
Old Feb 14, 2006 | 07:10 PM
265\75\16 stock rims
checkster
Dec 13, 2010 01:00 PM
sheriffav8r
Aug 27, 2010 09:10 AM
dansdad
Aug 23, 2004 12:26 AM
70DUSTER
Apr 10, 2003 01:36 PM
