Fuel Problem????
Old Nov 12, 2010 | 09:39 AM
gofastman's Avatar
Fuel Problem????
Ok i turning to everbody here,
I have a surging problem, but only at cruise speed! NOT pulling a hill or going down, only on the flat, just to keep speed, now it does this both on cruise control and on the throttle.
If im on cruise or by pedal and ask for moderate throttle it will go and smoothes out, when you hard throttle it, it will really go with no problems at all, This is only at light throttle speeds.
I have replaced the fuel filter, the fca, apps, with no help.
Could this be a cp3 going out, but why does it run so well at moderste and heavy throttle both on cruise or pedal.
Any help would be great...
No codes, no lights,
i dont have fuel pressure reading
but my pyro stays at around 550 and my boost is at 6 to 8.
Thanks in advance
Old Nov 12, 2010 | 01:25 PM
rich's Avatar
i would check the lift pump first since the cp depends on it way more then a vp does.
Old Nov 12, 2010 | 01:48 PM
gofastman's Avatar
lift pump
Lift pump was replaced with the intank version. If the lift pump was failing, wouldnt it effect the high demand at full throttle more than at cruise.
Old Nov 12, 2010 | 04:49 PM
Nsomniac05's Avatar
I think it would yes. Does it run abnormally hot or smoke more? could be a leaking injector.
Old Nov 12, 2010 | 08:03 PM
gofastman's Avatar
no smoke no other problems at all, it runs great other than that, it starts very easy and very quick, cold or hot
Old Nov 13, 2010 | 02:17 PM
gofastman's Avatar
used a buddies truck and we took the cascade and the fuel pressure valve, and it seems to running better, havent driven it yet much will know more tomorrow afternoon how we did. will keep you updated
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
