fuel problem
Old Jul 26, 2008 | 08:29 PM
renacolt's Avatar
fuel problem
O.K. I noticed no posts to other question. Update, If I have to push the shutoff solenoid up after key turned it has to be the problem, right? I took off the fuel filter and it was completely empty after at least an hour pumping the primer pump.
Anyone?
Old Jul 26, 2008 | 11:49 PM
Diesel Doc's Avatar
if the filter is empty the lift pump probably died or you have a hole in the line somewhere
Old Jul 27, 2008 | 10:08 AM
infidel's Avatar
Don't replace the solenoid, you will be wasting your money.
The solenoid only lifts when the starter is cranking, on key position holds it.
If it isn't lifting the problem is likely the lift relay on the firewall or a corroded blue wire at the driver's side battery positive.
Old Jul 31, 2008 | 08:01 AM
renacolt's Avatar
thanks
Thank you for all the advice, you guys are life savers. You were right, solenoid was fine after relay replaced. But it still won't start and no fuel. How do I test the pump?
Old Jul 31, 2008 | 08:31 AM
John Faughn's Avatar
You need to tell us what you have , yr , model , mods .
Old Aug 1, 2008 | 01:31 AM
renacolt's Avatar
sorry
Sorry I have another post with same problem and didn't realize I forgot to mention my truck. It is a 1995 dodge diesel 2wd.
Old Aug 1, 2008 | 02:05 AM
Dan Turner's Avatar
I had a crack in the pick up assembly, inside the fuel tank once. It still ran...barely, but took a while to figure out. Maybe another option to look at.
-Dan
Old Aug 1, 2008 | 02:45 AM
renacolt's Avatar
pump?
I was looking online for parts and three different fuel pumps came up. which one is it?
Old Aug 2, 2008 | 08:02 AM
Hammily's Avatar
It looks like this. Its a Carter pump the cheapest place I found it was from Cummins. Tell them you have a 95 5.9 Cummins in a Ram and they will set you up. I just replaced mine a few months back and it was about $100.00.
Old Aug 2, 2008 | 08:59 AM
I lost it , I had an address & telephone for ,
Marty Thompkins
Diesel injection service & turbo
in Michigan , he had the best prices when I replaced my LP & OFV , about $135 , about 1 1/2 yrs. ago so may have gone up like everything els .
Hope to find his info again and file away better , no internet site last I new .
Old Aug 2, 2008 | 01:03 PM
cummulator's Avatar
fill your tank up with diesel first. If its low on fuel or even below a quarter tank it is almost imposibe to prime. Fill it first, if you didn't have troube with extended crank before your lines should be fine. try that before replacing anything else.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
