Fuel Pressure - Pressure or Gauge ?
I have a 2004 with an Airdog2 which is monitored by a newer Dipricol electronic fuel pressure gauge. The fuel press sensor is mounted to a Vulcan 90 at the CP3. I usually show 20 psi at idle and when driving 110km the pressure sits around 16 steady. I was on a 8 hour drive yesterday and every once in a while the pressure needle was buried at 30+ psi and would just stay there. Then it would go back to normal. If i came off the throttle the needle would come back to the normal pressure and operate normal. I kind of think it is either the gauge or the pressure sensor. What do you think and has anyone seen this ? If it is the sensor i wonder if vibration at the CP3 is messing with it. If so maybe ill remount it in the big line kit line instead. Ideas/Suggestions ?
I thought there was a thread recently where someones gauge went up to 100 psi, and it was discussed that it was a bad pressure sending unit. You might have the same issue. Be sure to always check grounds and connections on all electrical issues first as well.
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
