Fuel pressure gauge
Old Jun 6, 2005 | 04:42 PM
slowerthanu's Avatar
Fuel pressure gauge
Ok, I have a Westach 0-15 PSI Fuel pressure Gauge on my 2000 CTD.
I am trying to determine if I have a LP going out or if my Sending unit is to blame.
It will Occasionally read 9 psi at Idle and 7 at WOT.
But most of the Time it will read what it has always read 13-15 PSI at Idle and 9-12 at WOT.
Do lift pumps work good sometimes and bad at others when they are on their way out or is this a case of a failing Sending unit?
I have an aftermarket warranty and occasional lack of power (Injection pump?) so if it is going I am going to let it go all the way and have both replaced.
Dan
Old Jun 6, 2005 | 04:55 PM
crobtex's Avatar
My bad lift pump was coming and going. I replaced it with a FASS II yesterday.
Old Jun 6, 2005 | 05:36 PM
farmer dave's Avatar
I have heard of people having this problem. They have good pressure and then it will drop. These are signs that the lift pump is going bad.
Old Jun 8, 2005 | 12:37 AM
Sea Bass's Avatar
I would suggest using a manual gauge along side your electric gauge. I was having strange readings with my westach when I first installed it so I hooked up a manual on the other shrader valve on the pump and noticed a huge difference at times. The electric gauge would drop to 5psi and then to 0psi and back up to 13-15 . The manual gauge never skipped a beat so I knew it was the sending unit.
Hope this helps.... Doug
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
