Fuel Pressure Gauge
Old May 27, 2004 | 09:02 PM
FARGO's Avatar
Fuel Pressure Gauge
What range does an electric fuel presure gauge need to have for a stock 2000 5.9 Cummins with auto trany?
Do I need 0-30 psi or is a 0-16 psi sufficient ?
Tx in advance for the help.
FARGO
Old May 27, 2004 | 09:23 PM
amartinson's Avatar
IMO 0-16 is pushing the mechanical limits of the gauge. It may never give you any problems, but I would opt for the 0-30.
Old May 27, 2004 | 09:24 PM
nitrousn's Avatar
the 0-16 will work. if you change/ mod the lift pump you might wish you went with the other
Old May 30, 2004 | 12:59 PM
MK4288's Avatar
for the most accurate reading you want the needle to be the center of the reading scale
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
