Fuel Pressure
Old Oct 1, 2009 | 04:41 PM
samaf's Avatar
Fuel Pressure
I just installed a fuel pressure gage and my pressure seems to be running low. At idle runs 10 psi at 60 runs 8-10 psi. If i get on the throttle it goes to 2-4 psi until i back off for a short time. Is this a indication the transfer pump is going bad? Need info asap as I am going on a trip in about 2 weeks. Also can you suggest a good transfer pump that will not break the bank.
Thanks
SAMAF
Old Oct 1, 2009 | 08:57 PM
rich's Avatar
i would say its getting weak, i used to run holley blues whole set up cost me around 200
Old Oct 6, 2009 | 05:34 PM
jrippamonti's Avatar
depending on your year you should be running around 15psi deadhead
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
