Fuel filter change
Old Apr 30, 2009 | 09:19 PM
who's ram's Avatar
Fuel filter change
Help me. I am using an iphone to post and i am stuck. I changed my fuel filter yesterday, and i still cannot get my truck to start. I have loosened the banjo nut to bleed, and plenty of fuel, so i have moved to the lines on the IP. I have broke free all of the lines, tried to start and fuel is coming out of every port. What else could it be? I have a job interview i have to make in the morning and no mode of getting there!! please help
Old Apr 30, 2009 | 10:15 PM
HotRodTodd's Avatar
If you are positive you have fuel pressure and your lift pump isn't shot, tighten your injector lines back up and hold the accelerator pedal to the floor and crank it till it starts.
Try not to crank it for more than 30 seconds at a time, while allowing a 2 minute cool down between cranking attempts.
Old May 1, 2009 | 07:24 AM
patdaly's Avatar
Also make sure you have fuel under pressure coming out of the ports.
The first 24V I worked on had fuel that would come out when you spun her over, just didn't have any pressure. Changed the LP and she fired right up.
Old May 1, 2009 | 09:45 AM
johnh's Avatar
where are you? maybe i can help
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
