fuel filter
Old Sep 15, 2005 | 04:21 PM
Tsutter's Avatar
fuel filter
Does any know how to change the fuel filter on a 2000 CTD?
Old Sep 15, 2005 | 05:12 PM
P.J's Avatar
P.J
Here it is.
Make sure you don't over tighten the cap when you put it back togther, it'll squeeze out the O Ring.
Old Sep 15, 2005 | 05:13 PM
P.J's Avatar
P.J
Theres a couple of other tips and tricks I can't remember right now, someone else will chime in.
Good Luck.
Old Sep 15, 2005 | 06:16 PM
Dr. Evil's Avatar
Dead easy job. Its important to fill the fuel filter canister with fresh, clean diesel, before you put the top back on and bump the starter (engage the starter so that the truck doesnt start, but the lift pump runs for about 20 seconds). Here is where you find out if your lift pump is working or not.
Theres some really good istructions here:
http://www.dodgeram.org/tech/dsl/fil...uel_filter.htm
Old Sep 15, 2005 | 06:41 PM
Tsutter's Avatar
Smile
How do you take the filter off? There is a hex nut on top & A 1/2 square drive inside of it. Or do you loosen it from the bottom? I have changed diesel fuel filters on my tractors & dozer so I know to bleed them before starting. The filter I have you cannot pre-fill. Hole in top & bottom
Thanks
Old Sep 15, 2005 | 06:43 PM
Tsutter's Avatar
Cool
Thanks Dr.E they are good instructions !!!!!!!
Old Sep 15, 2005 | 06:55 PM
Dr. Evil's Avatar
Do NOt use a ratchet or anything else in the 1/2 hole....it will crack the top. 1 1/8" socket
I guess you have one of the older fuel filter housings.
Old Sep 15, 2005 | 08:18 PM
J BODY's Avatar
Can't remember if the 2000 has the schrader valve up by the VP? If it does like my 01, I'll push in the valve while the pump is running when you "bump" the starter. It will hiss and spit until you finally get good fuel flow. When it does get flow it will start right up no prob.
Old Sep 15, 2005 | 09:03 PM
12PACK's Avatar
This is from a 3rd gen owner and I'm not sure how the 2nd gens differ, but here's the link: https://www.dieseltruckresource.com/...threadid=68532
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
