front end nightmare!
Old Oct 5, 2006 | 10:04 AM
qcstunter's Avatar
I changed the front right hub assy. on my 98 4x4 with 4 wheel abs. The axle nut stripped the threads on the outer axle so when I replaced the hub and put everything back together I just ran the nut on there the best I could and put in the cotter pin. BAD IDEA! I havent even drove the truck 2 miles on the way to work and the hub came apart and the wheel was flapping. I was almost ran into someones front yard. And no brakes cause the piston got pushed in the caliper when the wheel was flapping. Now My dana 60 is leaking oil where the inner axel goes in. How can I replace the seal and where can I get and outer shaft?
Old Oct 5, 2006 | 11:05 AM
qcstunter's Avatar
I see that I have to take the differential carrier out to change the seal. I still cant find this outer axle anywhere.
Old Oct 5, 2006 | 11:29 AM
mr T's Avatar
how did this happen? did u forget to put on the 4 bolts from the other side?...anyways any place that deal with axles can get u that shaft cause dana axles are very common...and i believe u change the seal from the inside of the pumpkin
Old Oct 5, 2006 | 11:34 AM
53 willys's Avatar
try this....
http://www.ringpinion.com/
Old Oct 5, 2006 | 11:35 AM
qcstunter's Avatar
I did not forget the four 12pt bolts. What happened is the new bearing that comes in 1 piece is now in 2 pieces. I think it has something to do with the stripped axel nut because it has to be tourqued at 140ft lbs.
Old Oct 5, 2006 | 12:15 PM
Mcmopar's Avatar
175 ft/lbs is the spec. If the large nut came off, then the bearings in the "hub" will seperate, and the whole mess comes apart. You are correct, you need to drop the ring gear to change the seal.
Old Oct 5, 2006 | 03:18 PM
qcstunter's Avatar
I thought I would be alright to make it to work this morning. When I took the center cap off of my tire the big bolt and cotter pin fell out.
Old Oct 5, 2006 | 10:18 PM
qcstunter's Avatar
ringpinion.com told me $140, but I wouldnt get it till monday. Is there anywhere else? I am thinking about getting a dynatrac freespin kit but I dont know if it will work with 4 wheel abs.
Old Oct 6, 2006 | 08:11 AM
Mcmopar's Avatar
Do you have a "fleet pride" or other heavy truck place nearby? I would get all my Dana parts from them, in my area it used to be "Universal Joint"
Old Oct 8, 2006 | 05:56 PM
qcstunter's Avatar
I dont know of any places like that but I will try to find out if there is one in the greensboro area, or charlotte.
Old Oct 8, 2006 | 06:01 PM
qcstunter's Avatar
found a fleetpride in greensboro. Do I just tell them 30 spline dana 60 outer axel? Is there a vin number on the axel that they could use for reference?
Old Oct 9, 2006 | 08:35 AM
Mcmopar's Avatar
The Dana axles have a BOM (build of materials) stamped into the axle tube. It might be tough to find, but it is there. Most times they can find what you need just by the application. ie 2000 Ram 2500, etc,etc.
Old Oct 9, 2006 | 06:42 PM
qcstunter's Avatar
it is a 30 spline correct?
Old Oct 10, 2006 | 07:51 AM
Mcmopar's Avatar
I assume you mean the part that splines to the "hub" assembly? If so I am not sure sorry.
Old Oct 10, 2006 | 10:27 AM
53 willys's Avatar
if the axles out of the truck just count the spline's
Ruckus
Aug 14, 2011 03:49 PM
shawn880
Nov 18, 2007 09:53 PM
Gordonville
Apr 18, 2005 09:45 AM
propinc
Aug 1, 2003 11:11 AM
NWDave
Mar 27, 2003 12:10 AM
