engine light code P0514
Old Apr 19, 2007 | 04:11 PM
kenzie's Avatar
Unhappy engine light code P0514
I could not find this on the one list I found. I believe it has something to do with the oil pressure as it was extremely high on the guage and the engine light was on. is it a switch or the oil pump itself
Old Apr 19, 2007 | 04:19 PM
dodgezilla04's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
0514 is the battery temp sensor. It is just a pita code. nuisance really. dont worry at all about it.
Old Apr 19, 2007 | 04:34 PM
kenzie's Avatar
thanks
should I worry about the engine light being on??
Old Apr 19, 2007 | 04:55 PM
it will go out after a few warm up/cool down cycles if the trouble that set the code has gone away.
welcome to DTR by the way. you didnt list what the truck is and where you are located. did the weather just change significantly? that can cause the screwy battery temp code. as long as that is the only code listed, just ignore it until it goes away, may take a few days.
Old Apr 19, 2007 | 06:01 PM
kenzie's Avatar
thanks for the welcome - I've found this forum before but kind of freaked when the pressure stayed so high as I am going on a 3 hour one-way drive next weekend.
I am in Wilton, CA (near Sacramento) and have a 2500. I have always driven trucks (ford/chevy/gmc) and this is my first dodge.
the weather is changing but it was not a sudden change.
it was interesting to find out how to get the code - never knew how to do that -
Old Apr 19, 2007 | 11:03 PM
labreck's Avatar
i just fond some info on your code p0514 and it talks about temp sensor and a flash to correct code. http://dodgeram.info/tsb/2006/18-022-06.htm
Old Apr 20, 2007 | 02:55 PM
kenzie's Avatar
it appears I will have to take it to the dealer to fix this?? my warrenty ran out about 2,000 miles ago - double darm
Old Apr 20, 2007 | 03:31 PM
wreedCTD's Avatar
they should fix a tsb without warranty i would think.
Old Apr 24, 2007 | 07:34 AM
Toto's Avatar
A common code.
Mine was "fixed" and came back.
The only way I knew it came back was to do the ingnition key code check thingy.
I believe there is a TSB, but I have not got arround to doing it.
I believe it is just an annomoly with no real consequenses.
I believe it is triggered by under hood temps caused by having the block heater on for hours at a time ...could be wrong tho.
Has anybody had the TSB done successfuly?
Old Apr 24, 2007 | 09:40 PM
WildBill's Avatar
TSB's are for information, they are not covered by warranty.
Old Apr 24, 2007 | 11:00 PM
mj007's Avatar
What? I don't know of anyone that's had to pay for the flash laid out in '06 Hard start/ TSB 18-003-06 REV. A. Or do I not understand what you meant?
Old Apr 24, 2007 | 11:12 PM
WildBill's Avatar
If the truck is still under warranty and you take it in for the complaint covered by a TSB, then they will fix it for free. If it's out of warranty, they will charge you to do the repair. Safety recalls are free whether you are still within warranty or not.
ccw55
Feb 7, 2006 04:50 PM
doorguy
Jan 26, 2006 05:05 AM
BAJA MAN
Dec 10, 2005 06:17 PM
billyrae
Nov 19, 2004 06:00 AM
