where is engine serial number and...
where is the engine serial number.. i need the cover for my puke bottle and curious also if there is anyother serial number i can use that will be cheaper"ive heard of this before anyway"
Look on the upper left corner of the timing gear case, there will be a metal tag with the engine serial number, hp rating, CPL number, etc.
that is the number you will need, in order to get parts for that engine. That being said, I do believe that the catch bottle is a dodge part. This would mean that you need the last 8 of your VIN in order to get the right parts.
good luck
good luck
Bushy
Jul 16, 2005 01:50 PM
