Electrical Problem
Old Apr 30, 2006 | 01:10 AM
DoubleNicoll's Avatar
Electrical Problem
i have a 1990 cummins 3/4 ton, and im having a problem with my electrical, the first problem is that my entire engine and my whole body always has power to it? and second is when i pull the switch for my head lights they dont turn on, but i have this buzzing sound? and is it normal if when i unhook my battery terminal my truck should turn off?
Thanks, DoubleNicoll
Old Apr 30, 2006 | 06:14 AM
What on the engine is always powered up?
The headlight switches on these truck are a known weak point. Throw a switch at it, they're under $15 at most auto parts stores.
Yes, the truck should die if you unhook the battery. The fuel shutoff solenoid needs at least 8 volts to stay open.
Old Apr 30, 2006 | 07:30 AM
handymantim's Avatar
Yeah, what part of the engine are you getting a voltage reading from? Where are you putting the leads from the voltmeter? How many volts are you seeing?
In a normal world, the engine/frame/body is the ground so I don't know how you'd be getting positive voltage on the block.
bigredbrick
May 1, 2003 11:59 PM
feets
Mar 17, 2003 09:57 AM
al
Nov 18, 2002 11:03 AM
MD Muhr
Nov 14, 2002 05:27 PM
turbospl311
Oct 14, 2002 08:23 AM
