Electrical Issue
Old Aug 15, 2011 | 07:50 PM
lgp9999's Avatar
Electrical Issue
I am having an electrical issue with my truck that has disabled the starting circuit. When I apply power directly to the small lead that comes out of the starter it will crank, but not when I turn the key. I don't think it's the ignition switch itself, as I can hear a relay or solenoid clicking under the hood when I turn the key, although I have yet to determine the source of the sound as I only have one pair of hands until one of my neighbors gets home from work. The clicking is not the starter relay in the box though, as I removed it but it didn't eliminate the sound.
The only other thing I've found that isn't working is the power windows. I have checked and found that I don't have any power to the power window fuse either. Any ideas?
Old Aug 15, 2011 | 07:57 PM
lgp9999's Avatar
I have found the source of my problem. There is a 30a fuse in the under hood box called Ignition Run and it was blown.
Thanks all!
Old Aug 15, 2011 | 07:59 PM
roysleight's Avatar
You say you hear a clicking. The relay will not make an audible click. The solenoid will. Do you see 12 volts on the wire to the starter when someone turns the key to start? The window fuse will get power only when the ignition switch is in the "on" position. Hope this helps. let us know what you find.
Old Aug 15, 2011 | 08:58 PM
Hintonc393's Avatar
If it was me I would carry some spare fuses around for a while. Fuses don't blow for no reason, something on that circuit pulled more amps than it should have.
Old Aug 15, 2011 | 11:35 PM
lgp9999's Avatar
Yes, that was my thought as well. Unfortunately I got the last 30a fuse at the auto parts store, so I have yet to get my spare, but I will certainly be doing so.
Worst case scenario I could always do what I did to get to the auto parts store in the 1st place: borrow the 40a from the blower motor.
Old Aug 16, 2011 | 09:33 AM
infidel's Avatar
If it's 12 valve you have the click comes from the shutdown solenoid.
proudpapa97
Apr 25, 2007 11:13 PM
Gotlift01
Mar 1, 2006 04:43 PM
Hounddog
Jan 30, 2006 02:36 PM
greatwhite
Oct 9, 2005 10:03 PM
