91.5' won't start- electical
Old Aug 15, 2011 | 10:28 PM
samiam4's Avatar
Ok,
Here's the deal- truck needs to be moved ASAP and it doesn't run. I put a 47RH trans in it.. starter I took it out tonight and autozone tested it as good. Not sure why.. but things in the harness were smoking with the key held on.
How to find a short? What could cause it? Is there a relay between the ignition switch/ Neutral safety switch to the starter- maybe it's bad. What's fused ..?
Old Aug 15, 2011 | 11:25 PM
bentwings's Avatar
I have an AZ lifetime starter. I've "won" 3 times with it. haha
the last 2 times the starter tested good at the store but Ihad to take it apart to show the mgr the burned contacts. It simply will not turn the Cummins over with burned contacts. I keep a set of heavy duty ones in the glove box just in case however.
If there is high resistance inthe starter you may get smoking wires. make sure you have a good clean ground.
Old Aug 16, 2011 | 06:42 AM
samiam4's Avatar
So you think it might still be the starter?
Old Aug 16, 2011 | 08:08 AM
patdaly's Avatar
sam, have you turned the engine over manually since installing the trans?
Make sure it does not have something binding, if it doesn't then I think it will be your starter.
Old Aug 16, 2011 | 09:48 PM
samiam4's Avatar
yep-
I looked at the damage, wiring diagram in the truck book. @ the starter there was no heat damage and the starter works. Pulled the cable out and vola- it shorted on the support bracket @ the engine. Not fixed yet- but problem is found!
Still non-functioning. Maybe the wire is fried internally after the short.
TRH
Jun 27, 2012 07:59 PM
francis212
Apr 14, 2008 10:11 PM
DISTURBED
Apr 19, 2007 09:52 PM
Jake R.
Nov 27, 2006 12:36 PM
