electrical help needed
Old Feb 17, 2008 | 11:37 AM
somis13's Avatar
my power mirrors are not working, stereo and dome lights as well. I have checked the fuses, all are good. I cant seem to find out anything in the manual. can some one help me? I have to be missing something. is there another fuse or something somewhere else? I cant even find a fuse location for the mirrors or dome light.
Old Feb 17, 2008 | 11:54 AM
Scubasteve's Avatar
Check fuse 3 (40 amp) under the hood in the distribution box.
As far as I can tell the fuse for the mirrors and dome lights is fuse 17 15 amp.
Keep in mind my manual is for the 96 model year.
Jason
Old Feb 17, 2008 | 12:43 PM
somis13's Avatar
the fuses under my trucks hood are not numbered only the ones on the side of the dash are.
Old Feb 17, 2008 | 01:01 PM
Scubasteve's Avatar
If I remember correctly you should be able to test them with a test light which is usually better than a meter in this case.
Alot of times the fuses if there just tired or have been loaded on a regular basis will not blow and leave a visible black spot. For this a test light is a great thing to test them and you dont even have to remove them.
From what I can see your problems are not from just ONE fuse inside the cab so its safe to say its either the feed for those fuses in the panel which could be a bad fuse under the hood or a bad wire feeding to the panel.
A meter will do if you dont have a test light.
Jason
Old Feb 17, 2008 | 01:13 PM
Scubasteve's Avatar
Jason
Old Feb 17, 2008 | 02:30 PM
mrclean's Avatar
Check the IOD fuse. Should be #12 on the side of your dash. Hard to access/check because it has one of those black holder gizmos, gotta slide it out then unclip to get at the fuse. HTH
Old Feb 17, 2008 | 04:22 PM
somis13's Avatar
got it! thanks to mrclean. it was the #12 I.O.D. fuse that is a P.I.T.A. to access. I might not of tried to get the black holder off if mrclean didn't suggest it.
Moparman318360
Feb 23, 2013 10:07 AM
feets
Feb 3, 2011 07:04 PM
Ramified5.9
Apr 1, 2009 03:37 PM
bamaredneck
May 24, 2007 08:51 PM
Hummin Cummins
Mar 24, 2003 07:41 AM
