ecm question?
Old Nov 27, 2007 | 07:01 AM
critser660's Avatar
Angry ecm question?
Does anyone know , if my ecm is fried( as dealer says) would I be able to hold down on my odometer reset and cycle my key and the truck run through its diagnostic checks? I know I messed up and hooked up a Triple dog before it was back to stock setting from the last truck, but they said they get nothing when they hook up to it and it seems pretty convenient that its not an 80 dollar fix and is a 2000 dollar fix.( reflash vs. new ecm). Any thoughts?
Old Nov 27, 2007 | 10:03 AM
johnh's Avatar
http://www.ecm-ecu-online.com/dodge_part_numbers.html
Old Nov 30, 2007 | 03:15 PM
Richardk's Avatar
I would check fuses, when an aftermarket programer use to malfunction, the drb3 would throw little smilie faces all across the screen, but u could be experiencing a no communication if the truck will start and run. If not contact the tech support from the programer company. That is all i know to do man.
Old Nov 30, 2007 | 05:38 PM
infidel's Avatar
Yes, codes come from the PCM, not the ECM.
Old Dec 1, 2007 | 05:54 AM
critser660's Avatar
THanks guys. I guess this was just an expensive lesson. I got it all fixed now and back to work.
Old Dec 4, 2007 | 11:55 AM
flatshooter's Avatar
How? What did it take to clear problems with ECM?
Old Dec 4, 2007 | 01:12 PM
dssimecek's Avatar
On my 02, the key/code trick checks the PCM, a slight pause, then checks the ECM.
Old Dec 7, 2007 | 07:14 PM
critser660's Avatar
Well, the dealer said my old ecm was done so I had to get a new one. However after reading on this site that it is pretty tough to smoke the ecm , I asked for my old one back. They wouldn't reflash it , just said they could not do it. Since I was out of town and didn't really know anyone around, I just paid up and went away with my original and a brand new one. Someday I'll havve it tested and see if I have to go back to that dealer and ask for an explanation.
Old Dec 9, 2007 | 12:10 PM
J BODY's Avatar
However after reading on this site that it is pretty tough to smoke the ecm , I asked for my old one back. .
Pretty tough to smoke one, but not too hard to lock one up as you found out messing with a downloader.
Old Dec 15, 2007 | 03:04 PM
crash4wd's Avatar
hyypertech ecm
hey someguy let me download a hypertech programer to my truck it ran fine for two months and know it wont idle above 1300 and it blows alot of white smoke i not sure if the programer is messing up or what how i can delete it from truck
ratat98
Sep 18, 2016 07:34 PM
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
