Dumping fuel
Old Aug 26, 2009 | 09:30 PM
hostilecs's Avatar
Dumping fuel
I have a 2005 2500 dodge ram, that today started losing fluids out the breather hose on driver side. At first look like I was dumping oil. Did regual fluid checks all was ok. After cleaning it up a bit I started losing power and oil pressure gauge started dropping pressure. Now after second look it appears to be dumping raw fuel out the breather tube, and noticed thumping noise near intake. Had a Lead on possible fuel line leak? If so would it be internal or external and where do I look? Second, if internal where would I look and third if not internal or fuel line then any other possibilities/
Thanks Seriously worried!
Old Aug 26, 2009 | 10:20 PM
Riflemanusmc's Avatar
Registered user
Get it to a dealer. DONT drive it. Injectors or connector tubes..
Old Aug 27, 2009 | 05:04 AM
RPegram's Avatar
A fine example of why having oil analyzed is so important on these engines after 98.5. You can have a small fuel leak in there and never know it until you get that sinking sound of a thump on the lower end.
Old Aug 27, 2009 | 06:00 AM
scottsjeeprolet's Avatar
It should be covered under the Cummins engine warranty. How many miles on the truck?
Welcome to the DTR!
dieselnewbie
95
Sep 6, 2013 10:52 PM
trailinone
18
Jun 3, 2010 03:16 PM
tool
Oct 27, 2008 02:17 PM
dznutz24
Aug 28, 2008 01:25 AM
auroraflyer66
Feb 14, 2007 08:16 AM
