2004 abs/brake
Old Aug 26, 2009 | 10:06 PM
N8theGr8's Avatar
2004 abs/brake
the abs and brake light will not go away and i dont seem to have proper abs. the speedo seems to have a slight hickup from 0-10 and when u slow down it goes down to 5 back to then then to 3 then to 0.. changed the speed sensor in the rear end and in the tranny??
any tips?
Old Aug 27, 2009 | 06:45 AM
mishkaya's Avatar
any tips?
When I had those same symptoms on my '01, it was the rear wheel speed sensor located in the rear differential. It's worth a shot. Also check the connectors for corrosion as they will cause the same symptoms. Good luck.
fitzydog
21
Oct 11, 2017 12:09 PM
ppsi
Nov 22, 2013 08:26 AM
BigBore050
Mar 9, 2010 11:46 PM
BobQ
Sep 13, 2007 07:21 PM
mr T
Feb 24, 2007 06:42 AM
