Dual disc problems on 1st gen
Old Jan 14, 2010 | 04:42 PM
rbrettctd's Avatar
Havent had time lately so I dropped off my truck to have my SB DD clutch installed. Installer just called and said there were some problems. He said the clutch fork is wrong, that its for the NV4500...I thought these were the same? He said it would NOT work tho. Also said that the starter shims that come with it will only allow 2 bolts on the starter to be used, and that its a tight fit. Can someone tell what is wrong or what I need? This clutch was built by Peter specifically for a Getrag. Thanks. Need help asap as its tying up his bay and southbend is closed right now.
Old Jan 15, 2010 | 08:45 PM
RCW's Avatar
RCW
I have not seen one that would work with the OEM hydraulic clutch and fork system, so suggest you follow up with Southbend and identify if you should have the clutch cylinder and fork upgrade.
South Bend Clutch
South Bend Clutch
13
Dec 4, 2012 09:51 AM
rbrettctd
Jan 15, 2010 02:37 PM
n2moto
16
Jan 22, 2009 10:25 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
