Drain plug stripped!!!! HEEELP!
Old May 30, 2007 | 05:08 PM
Camarogenius's Avatar
Please tell me there's a neat trick for removing a drain plug that's stripped out. (The pan's not stripped, just the 3/8 suare hole in the drain plug is now round, and I can't get anything to get a bite on it.
Should I use a torch, and burn out the nylon ring?
Or should I break out the dremmel, cut some slots and go after it with a cold chisel?
Old May 30, 2007 | 05:09 PM
I already have a new plug, and nylon ring.
Old May 30, 2007 | 05:12 PM
vzdude's Avatar
DTR's 'Go to Guy'
try an extension on your ratchet.That worked for the last guy!Either that or foget the dremel an go straight to the cold chisel!
Old May 30, 2007 | 05:16 PM
Mud Ready's Avatar
Do you have a welder? If you do try welding an old extension into the hole.
Old May 30, 2007 | 07:17 PM
1-2-3's Avatar
Just a plain ole guy
You could sacrafice an old 3" extension and glue it in with JB Weld or a good strong epoxy. Clean the old plug well, then glue that extension to the plug. Let it dry overnight. Then unscrew it then next morning.
A good tip is to occaasionally replace the plug OR get a quick drain kit from geno's. (I'm planing on doing this) You screw it in one time and leave it. Then just add the second of the two parts thats snaps on and quickly drain the oil.
Old May 30, 2007 | 07:24 PM
darkvader's Avatar
get a large ez-out and grind it down so it does not bottom out in the plug. drive it in and turn.
Clark
Old May 30, 2007 | 08:56 PM
Deezel Nate's Avatar
I'd weld an extension or bolt to it. Just be careful with getting it too hot.
Old May 30, 2007 | 09:18 PM
dodgediesel's Avatar
A small pipewrench works great on the edge of the big head.
Old May 30, 2007 | 10:10 PM
dodgezilla04's Avatar
place sandpaper around the extension and drive into the hole.
Old May 31, 2007 | 12:21 AM
Mike Perez's Avatar
Pipe wrench, your done.
Old May 31, 2007 | 04:30 AM
Syndicate's Avatar
just go trade the truck in!
Old May 31, 2007 | 11:27 AM
Rampage1967's Avatar
Who needs to change the oil??
Old May 31, 2007 | 12:15 PM
CarBizIndio's Avatar
large vice grips
Old May 31, 2007 | 12:17 PM
cincydiesel's Avatar
These trucks have oil???
Old May 31, 2007 | 04:28 PM
mr T's Avatar
pipe wrench...watch ur head under there
