Doing water pump in 30 minutes..
Old Mar 26, 2008 | 10:40 AM
Invader's Avatar
Getting ready to do my pump in a few minutes, and the seal that came with it is a square cross section solid ring.
Per the instructions, it says to use tacker if it's a gasket, or lubricant if it's an o ring.
It's really neither. Should I use nothing?
Thanks.
__________________
Old Mar 26, 2008 | 11:12 AM
dieselrob's Avatar
I never had to do a water pump on any of our cummins' but i always put a light bead of rtv on any of the ones i did on other vehicles.
Old Mar 26, 2008 | 11:16 AM
John Faughn's Avatar
Either should work , clean the mating surfaces well .
The thing I do not like about silly cone , is that I see a lot of others using so much of it , that is some use way too much , squeezes out excess that can into things you do not want .
Old Mar 26, 2008 | 12:53 PM
Invader's Avatar
well, pump went in w/o a hitch, but now the radiator drain valve won't shut properly, and I have a bubble somewhere.
She's overheating really fast.
Old Mar 26, 2008 | 01:00 PM
dieselrob's Avatar
On the front left above the exhaust manifold by cylinder 1 there is an allen plug to the water jacket in the head. Its on top. Take it out and fill it up from there.
Old Mar 26, 2008 | 01:09 PM
Invader's Avatar
happen to be able to snap a pic of the right one perhaps? I see a few there (might be head bolts).
Old Mar 26, 2008 | 01:12 PM
Invader's Avatar
Better yet:
Old Mar 26, 2008 | 01:14 PM
Invader's Avatar
Ok, there is 1 small one, and 2 large ones before I run into the heater core hose.
Small one? Or the hex head bolt?
Old Mar 26, 2008 | 01:52 PM
winkle's Avatar
It's the small plug in between the 2 head bolts
Old Mar 26, 2008 | 02:21 PM
Invader's Avatar
ding ding ding ding.
Let her cool down, pulled that, was bone dry. Pulled rad cap, and kept filling, and coolant appeared at the small bolt. Bolted it back up, and topped of the rad.
Think I'm gtg, time will tell.
Thanks alot
Diesel_Power_2
Jan 25, 2011 10:34 PM
jthorpe
Apr 5, 2004 03:51 AM
robo
19
Jan 14, 2004 03:24 AM
Shaders 24v
Aug 18, 2003 09:25 PM
