Dodge Ram 2500 power problems
Old Oct 16, 2004 | 10:27 PM
scbyrne's Avatar
I am having a problem with the power in my Truck, I have no power to any of the instruments and the tranny won't shift out of second. Does anyone know what the problem is?????????
I do have power to everything else like lights and stereo.
HELP!!!
Old Oct 16, 2004 | 10:29 PM
Rattlerattle's Avatar
What kind of truck is it?
Have you check the fuses, including the ones under the hood?
Old Oct 16, 2004 | 10:31 PM
scbyrne's Avatar
Yes, checked all the fuses, I have a Dodge Ram 2500 Deisel 4x4 automatic.
Old Oct 16, 2004 | 11:05 PM
phox_mulder's Avatar
The year would be quite helpful as well.
phox
Old Oct 16, 2004 | 11:06 PM
scbyrne's Avatar
oops sorry...1998
Old Oct 16, 2004 | 11:08 PM
Ok, next question, 12 valve or 24 valve
phox
Old Oct 16, 2004 | 11:09 PM
scbyrne's Avatar
24 valve....
Old Oct 16, 2004 | 11:19 PM
Tranny not shifting out of second is known as "limp" mode.
Is it starting in 2nd as well?
You should have an accompaning code.
Autozone or any major parts place should be able to read the codes stored in the ECM/PCM.
The instruments are controlled by a computer, either it is bad, or the connection from the dash to that computer might be disconnected or dirty.
This would also show up as a code when you get it scanned.
phox
Old Oct 16, 2004 | 11:26 PM
scbyrne's Avatar
Actually yes it does start in 2nd....it all happened at the same time so...
I checked the block on the firewall under the dash it is still fully connected, I also unplugged three connections from the ECM and their was no corosion. I will take it to someone to have it scanned, thanks so much for your help Phox. Do you know how much a computer would run me if that is the problem??
Old Oct 17, 2004 | 04:52 PM
The 3 connector box on the firewall is actually the PCM, the Dodge computer.
The Cummins ECM is mounted to the engine, driver side.
No idea what either goes for, if that ends up being the problem,
more than likely it's just a sensor or connector problem.
phox
Donmacky
Feb 1, 2014 06:07 PM
marksblaster
Oct 27, 2012 11:26 AM
Journier
21
Nov 26, 2010 08:41 PM
bsj21
Dec 7, 2007 04:23 PM
