death wobble only when breaking
ok finally got my first case of death wobble and it came after i have now taken out my lift and only when i'm breaking. do u guys think that it could be that i'm running dons 5+ bar on a stock truck with a stock pitman arm
also i have NO steering stabilzer on there at all
I would put steering stabs on and see what it does then. Is there any weird angles on Don's bar? Or does it look normal? Is it a bad woble or minor, i.e. does the steering wheel shake or does the whole truck shake bad?
i had that problem take your truck and get it realined tell them the put the camber hard against the frame and square it forom there it cost me about ten grand to figure this out my truck dodnt do it if they alighn this way i now have 160000 on mine and it dont it eny more
well i think i found the problem.....the toe was way off when i got it alinged. Well took it out for a drive and dang if it was still there. So i get home and ahve the neigbor come over and turn the steering wheel while i sit under the truck and dang if I dont find that i must have forgotten to fully tighten up the axle end of the trac-bar. Sooooo i tightened that and all is good.......i feel stupid but at least it was an easy fix.
ok its back but only some times and only at about a certin range of break pressure soooooooooo i think its time for new pads and either turned rotors or new ones
725Gus
Mar 6, 2014 09:49 AM
MtnDodge
63
Nov 13, 2013 11:35 AM
Trooperthorn
Nov 30, 2010 12:06 AM
Jezzhuntin
Apr 11, 2007 04:52 PM
