Dealer miss diagnose
Cummins Guru
The dealership would have to run your vin and the part number to see if it is covered. Cummins engine is 5 years or 100k with $100 deductible.
If part isn't covered this site has part for reasonable price.
http://www.moparpartsamerica.com/par...ke=8&model=Ram 2500&year=2005&graphicID=TH03110&callout=7&catalog id=2&displayCatalogid=0
SHOPPING CART
Description Qty MSRP Price Your Price Core Price Total Cost
Collision Catalog - 2005 - Dodge - Ram 2500
Cooling, Belts and pulleys, Bearing, Bearing - 5.9 & 6.7 liter diesel - 5.9 & 6.7 liter diesel $204.00 $134.81 $0.00 $134.81
Total: $134.81
Estimated Shipping: FedEx GroundFedEx 2-Day ExpressFedEx Next Day ExpressWill Call Pick Up $14.83
SHOPPING CART
Total: $134.81
I'm betting A/C compressor clutch bearing.. Turn on the ac and listen for the click of engagment. The noise should stop instantly
Verdict is the fan hub carrer. It took a little work but I got it puled out. I took the carrer group to a local shop and had the baring presed out. Could not find a replacement so I got one coming in tomarow from Cummins out of Mobil AL. I plan on puting everything together tomarow. NOTE: Do not buy the cheap hub removel tool from Advanced.... The tool started to strip the main hub donection to the assembly. I used a cresent and a vice.
Fan hub bearing is making the noise, I have changed a few over the years so stop chasing your tail around.. Remove fan clutch and shroud. Four bolts and the fan hub and bracket will come off. Bearing needs to be pressed out and in after removing center bolt.
Here is a link to previous thread https://www.dieseltruckresource.com/...ng-t90506.html
Remove pulley #4 and then remove bracket with bearing. 25+ years Dodge experience, not bragging just fact.
roughstock
Dec 4, 2013 10:53 AM
Lionhart75
24
Sep 15, 2011 10:31 PM
HO Cummins
Nov 7, 2004 11:16 AM
Mar 25, 2003 05:39 AM
.... got two of those under my bench.
