dead battery and codes
Old Jan 21, 2005 | 09:17 PM
ChrisM55's Avatar
Question dead battery and codes
Left my key on for about 24 hours a couple of days ago and the battery went dead. Put the charger on it on 10 amps for about 18 hours then disconected it and plugged in the heater. When I went out tonight to start it up there was a check engine light on but it drove normaly all the way to work. I am clearing the codes now but I was wondering if anyone has any idea what in the world happened???
Chris
Old Jan 21, 2005 | 10:12 PM
ChrisM55's Avatar
OK, I tried to clear the codes but it still has the check engine light!!! any ideas, truck is running great with the exception of that check engine light
Chris
Old Jan 22, 2005 | 06:15 AM
handymantim's Avatar
Your check engine light is most likely the result of the batteries going dead and will go away after "X" number of successful engine cycles. That X is usually 3 for most problems but I think it can vary. Also, a "successful engine cycle" can vary but for the most part it is defined as the engine going from cold up to operating temperature.
Do you know what the codes are? If you can't get them out yourself which I'm not sure if you can on a 99 then go to Autozone and have them pull them for free.
Old Jan 22, 2005 | 06:35 AM
ChrisM55's Avatar
I got the codes to clear but I will have it scanned anyway. I don't know if it was just the starts or that I pulled the fuses to the ECM and PCM for an hour. Thanks for the help, if I had known about that code clearing I would have just left it alone and run it, OH well
Chris
Hawkeye
Apr 17, 2012 11:50 PM
s cesnick
Apr 16, 2010 08:17 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
