cruise control
Old Feb 3, 2009 | 08:57 AM
dalefans2's Avatar
cruise control
Hey all,
My '99 1 ton 4 x 4, 5spd cruise will not stay on. As soon as I hit the on control on the steering wheel it immediatley shuts right back off. In order to try to turn it back on I have to shut the key switch off to clear it or something. I do not get any codes with this issue. Wondering if it could be the clock spring, switches in the steering wheel or something in the inj. pump. No doubt it will be the ecm!
Thanks
Old Feb 3, 2009 | 09:45 AM
dozer12216's Avatar
Originally Posted by dalefans2
Hey all,
Thanks
I seriouslly doubt will be ECM. My best suggestion is get a dealer to hook up scanner and look for sensors and switches. There is a display screen to show operation of inputs and outputs. Hate for you to dump $200 in a clockspring only to find a maladjusted brake switch.
Old Feb 3, 2009 | 10:29 AM
infidel's Avatar
Pretty common for the brake switch on these rigs to fail, they're cheap.
Try lifting up the brake pedal with your foot while engaging the cruise at at least 40 mph.
If that works buy a new one, about $12 at Napa, takes a couple minutes to install.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
