Cranks but won't fire
Old Mar 2, 2008 | 03:17 PM
06 DIESEL's Avatar
Here is the situation, I went to start my truck to take it over to a buddies to hook up the FP gauge again, (needed a new fitting after the Air Dog install) and it won't start. It started to fire then I stopped cranking and it shut off. Now it only cranks but will not fire. I tried to hook up my smarty for codes but it will not connect, not sure why but it keeps telling me to turn the key off, then on, then says connecting, then back to the key thing. The Air Dog is not pumping anymore, normally you could hear it when you first kicked the key but now it just sits there. The key trick has never worked for me, not sure why but I have never gotten it to work. There are no fuses blown, nothing unhooked, everything looks good. Anyone got any ideas?
In the last month or two I have added the Air Dog, SB DD 3600# clutch, and Smarty. Truck has just over 31k on the clock now and it ran fine yesterday, no signs of anything on the way home last night.
Any ideas?
Old Mar 2, 2008 | 03:27 PM
Bob Wagner's Avatar
the smarty is having a problem communicating with your ecm. when it keeps telling you to turn key on /off/on/off. communication link is not established
hope this helps
Old Mar 2, 2008 | 03:42 PM
06 DIESEL's Avatar
Any ideas why this might be? I figured that it was having a problem connecting because it kept telling me that no matter what I tried, read codes, change tune, etc.
All relays and fuses are good, I have the batteries disconected currently trying to reset the ECM.
Old Mar 2, 2008 | 04:36 PM
Bob Wagner's Avatar
I think your tipm took a crap on you. dealer will fix under warranty. you can try unplugging the main connector on the underisde.
Old Mar 2, 2008 | 06:00 PM
06 DIESEL's Avatar
Got it to start, there was a bad ground on the drivers side battery.
Old Mar 2, 2008 | 06:07 PM
Bob Wagner's Avatar
and thank you for calling. that was very courteous of you.
Neal Cassady
Nov 19, 2013 09:27 AM
69nova
Feb 12, 2012 06:20 PM
zc4life
Dec 19, 2006 08:34 PM
BsWhiteDodge
Mar 23, 2005 06:26 PM
Yukon Dodge
Mar 30, 2004 09:46 AM
