Crank Pulley
Crank Pulley
My tach started bouncing around this morning on the way to work and after I got there I lifted the hood with the truck idling the harmonic balancer or crank pulley which ever looks like its about to wobble off. I tried to move it with my hand to see if it was loose and doesn't appear to be. Anyone ever had this problem?
If the truck is a 5 speed, use a pry bar to see if you can move the crank back and forth. The thrust bearing my be shot.
You may have to remove a pulley and belt to check the problem out. If you can get a clear shot at the harmonic damper itself with an inspection mirror see if the outer rim is separating or 'off kilter' with the center hub part. There is an elastometric/rubber filler between damper hub and rim and as mentioned it can separate. Not a hard fix if that's the case, but you'll probably need a harmonic damper puller to do the job. Being a diesel the new damper shouldn't be more than 4-5 times the cost of a comparable gas engine damper part.....
JimmieD
JimmieD
Originally Posted by RCW
The balancer is of two piece construction with a rubber spacer cast between the inner and outer rings. Once they start tossing the rubber it is time to replace them.
how do you keep the crank from turning over on with automatic trans
I got two of the four bolts loose but the other two are too tight and the crank keeps turning when I put alot of pressure on the pullhandle
1985cucv
Dec 19, 2009 12:48 PM
chali84
Dec 17, 2007 12:18 AM
NoSparkplugs
Feb 26, 2006 08:17 PM
