crank position sensor
OK! I know I'm gonna catch H*** for my choice of truck body BUT, I'm crankin' a 5.9 Cummer.
I need to know which wire is which on the crank sensor. There are 3 wires in a round
connector with a flat tab for alignment. I'm hookin up my Ferd tach to the Cummer sensor.
ie: volt, ground, signal
Thx
59
Thx
59
CPS
95 Dodge FSM says a CPS has 3 terminals labeled 1 2 3.
terminal 1 connects to PCM on pin 7 which supplies 8 volts to CPS and trans speed sensor.
terminal 2 connects to PCM on pin 4 sensor ground circuit
terminal 3 connects to terminal 24 the input to the PCM
.........................#2
front of engine.....#1
........................#3
hope this helps
mel
hope this helps
mel
kingofdodge7131
May 24, 2004 01:09 PM
