Coolant Leak
I have coolant leaking from rear of engine. It is dripping from the bottom of adapter between engine and bell housing. Am going to try to get a better look tomorrow afternoon with mirror and good light from underneath. It is not a fast leak--just a slow drip. Was hoping someone might know what this is. I have looked at the core plugs I can see with just the light from above and see no evidence of leaks.
Well you have three choices that I know of that would be in front of the adaptor. There is a freeze plug on the back of the block, do a search, there was a thread on another one. It could be the head gasket leaking at the corner on the drivers side. And I think there is a small freeze plug on the back of the head. Also take a good look on the passenter side torward the rear of the engine where the block steps down in width, hope it is not leaking there.
I agree with all the possibilities from thumper and hid. Try to clean things up as good as you can and use a pressure tester on the rad. Watch for leaks while cold and eng off. If it is a hose or core plug it will leak immediately. If it has to be warm to leak watch closely arround the head gasket area. Good luck
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
george7941
Nov 28, 2009 09:28 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
