code 252 undetected
Old Nov 5, 2007 | 07:03 AM
skidooer76's Avatar
code 252 undocumented
Does any one know what this code means, it only seems to happen when you put the small pedal to the floor the tranny is slipping bad which causes motor to over rev, tranny is getting fixed but just trying to figure out the code, any help would be great.
Old Nov 5, 2007 | 07:08 AM
vzdude's Avatar
DTR's 'Go to Guy'
Uhhh ohhhh, sounds like an injection pump going! Do you have the wire tapped? - could be a bad connection. Other than that, here's the info on the code.
Symptom:
P0252-FUEL VALVE SIGNAL MISSING
When Monitored and Set Condition:
When Monitored: After current feedback monitoring is complete. Average engine speed is
above 700 RPM.
Set Condition: The ECM does not receive a signal from the solenoid valve indicating
valve movement.
POSSIBLE CAUSES
FUEL INJECTION PUMP
TEST ACTION APPLICABILITY
1 Turn the ignition on.
With the DRBIIIt, erase ECM DTC’s.
Test Drive the vehicle.
With the DRBIIIt, read ECM DTC’s.
Is DTC P0252 present?
All
Yes ® Replace the Fuel Injection Pump in accordance with the Service
Information.
Perform POWERTRAIN VERIFICATION TEST VER - 5.
No ® Test Complete.
94
DRIVEABILITY - DIESEL
Old Nov 5, 2007 | 07:11 AM
skidooer76's Avatar
No the wire is not tapped
Old Nov 5, 2007 | 07:14 AM
vzdude's Avatar
DTR's 'Go to Guy'
You can check all the connections at the back of the IP, but if everything looks good............plan on a new IP sooon!
Old Nov 5, 2007 | 07:32 AM
skidooer76's Avatar
ok , when the code is pulled up in the scanner there is no P or zero it just says 252 undocumented is this the same a the P0252 code?????
Old Nov 5, 2007 | 07:35 AM
vzdude's Avatar
DTR's 'Go to Guy'
Ummm.....what kind of scanner are you using? Most of them have even a brief generic description of the code. All other modules on your truck do not use a numerical code. 'Bout has to be a powertrain code.
Old Nov 5, 2007 | 07:41 AM
skidooer76's Avatar
snap-on scanner
winkdemon
ABDTR #5
Jan 18, 2012 11:10 AM
1965427AC
Nov 28, 2008 06:24 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
