clutch or hydralic
Old Jul 3, 2010 | 07:58 AM
dustyman440's Avatar
clutch or hydralic
towed home a piece of equipment thursday for the shop truck worked fine unloaded it and went to move truck it wouldent go into gear replaced hydraulics still same if you shut truck of you can select any gear start in gear it lurches forward a little thought it was clutch put in southbend 1947o still does the same need to get truck going asap flywheel was surfaced .015 help
Old Jul 3, 2010 | 09:49 AM
a&b guy's Avatar
Well if you replaced the cluctch master cylinder and slave cyliner and bleed it properly(in which the only time it works for me is vacuum bleeding, and you still have problems then its linkage. The fork to the throwout. unless there is something bound with the cluch itsself(unlikely). Hope this helps!
Old Jul 4, 2010 | 09:31 AM
BigIron70's Avatar
Cummins Guru
Was the fluid in trans ok and to proper level?
Old Jul 4, 2010 | 11:22 AM
fluid level is correct amsoil trans fluid
Old Jul 4, 2010 | 07:43 PM
BigIron70's Avatar
Cummins Guru
You can try putting trans shifter in neutral then disconnect drive shaft from rear axle. You should be able to turn driveshaft with little resistance. If you cannot you have something binding up in trans. Could have air in clutch cylinder. Did trans go in easy (clutch splines lined up perfectly with pilot bearing? or did it seem to bind up? I have seen clutch disk get damaged if too much of trans weight was put on it while installing trans. This could distort the clutch hub and not let it disengage when clutch is depressed.
Old Jul 5, 2010 | 06:41 AM
i,ll try to disconect the driveshaft and see how it turns trans went back in perfectly
cLAYH
ABDTR #5
Feb 21, 2010 03:34 PM
whiteknight
Mar 17, 2008 04:21 PM
stroker4501
Feb 9, 2008 04:15 PM
2500
Oct 2, 2006 09:14 PM
