Chip Screw Up My 24V NEED HELP!!
Old Mar 3, 2005 | 05:02 PM
MarkSupply's Avatar
Hi I have a 1998.5 24Valve dullay, 4x4, 5spd, quad cab, Now for the problem I pluged a Chip in to my truck and it would not start so I check all the plugins and tried it again It still would not start so I unhooked it and it started BUT NOW when it is hot it cranks longer to start, What do you think it might be also When I run it hard and then stop it will like high idle? I need help. Thanks Nick
Old Mar 3, 2005 | 07:12 PM
JKM's Avatar
JKM
Sounds like maybe a vp44 going south? have you checked for codes?
Old Mar 3, 2005 | 07:29 PM
Shovelhead's Avatar
Administrator / Scooter Bum
What brand and model box were you using?
Old Mar 3, 2005 | 07:53 PM
BigBlue's Avatar
Definately sounds like an injection pump.
Old Mar 3, 2005 | 08:15 PM
mkrenn's Avatar
Codes?
Old Mar 3, 2005 | 08:16 PM
MarkSupply's Avatar
It was a Vanhagen 50hp on setting box. It will always start but it cranks for like 10sec and dont fire right off like my dads 12V does. Thanks for all the other replys very helpful.
Thanks Nick
Old Mar 3, 2005 | 08:18 PM
MarkSupply's Avatar
To get the codes should I buy one of the scan tools for my truck or should I take it to a local grage and have them check it? Thanks Nick
Old Mar 3, 2005 | 10:04 PM
Wilson's Avatar
Try turning your key to the accessory on position and then off and back 3 times, then look at your odometer, it should flash some four digit numbers or if there are no codes it will just say done.
Old Mar 3, 2005 | 10:05 PM
phox_mulder's Avatar
Not on a 98, or a 99.
phox
jmd4993
Jun 22, 2013 07:36 AM
LUKE-MM-PULLER
Oct 17, 2007 02:02 PM
loudcummmin
Oct 3, 2005 02:44 PM
cowdude
Feb 19, 2003 06:20 PM
