Is there a screw on fuel filter conversion for the 24V
Old Oct 17, 2007 | 01:10 PM
LUKE-MM-PULLER's Avatar
I just changed my fuel filter and I was wondering if there was a conversion kit to make it a spin off type.
Old Oct 17, 2007 | 01:47 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
http://cgi.ebay.com/ebaymotors/01-Do...8228QQtcZphoto
This is what I have. It only takes a few minutes to change, and so very easy to bleed. After installing the new filter, spin on the top and then just bump your key (but not starting motor) about 4 or 5 times. You need to wait a minute os so between each bump. Then start up and go.
Old Oct 17, 2007 | 01:58 PM
Dinner's Avatar
FleetGuard should carry something like that as well. They look pretty much just like that one. I see them on the ISB Cummins Garbage trucks we service all the time. There like 1 1/4 socket on top, so you loosen the entire lid, pull it off and the filter is snapped into the lid. The canister will stay filled with fuel and away you go putting the new one back in. Probably should drain a bit of fuel out and install the filter slowly or else you will be sprayed with fuel...
Old Oct 17, 2007 | 02:02 PM
JPR Ram's Avatar
The one above I posted is what comes stock on 2000 to I believe 2006, maybe 2007.
jmd4993
Jun 22, 2013 07:36 AM
Subliminal
Jun 16, 2011 03:26 PM
loudcummmin
Oct 3, 2005 02:44 PM
MarkSupply
Mar 3, 2005 10:05 PM
