check engine light, no charging
Old Jan 6, 2010 | 07:50 PM
JWood's Avatar
hello. I have read in the past that you can use an external voltage regulator on the first gens.
can someone post the link to the Napa part number and a diagram to hook it up...? thanks in advance.
I can troubleshoot from there.
I appreciate all of your help.
Justin
Old Jan 8, 2010 | 07:55 AM
JWood's Avatar
wow, I am the first guy here to actually get ZERO replies in the "emergency help" section... thats got to be worth something.
it was quite simple to find the thread after some searching. however I was interested in hearing what others recommend on which type of external regulator to use. but Ill post that later.
the problem turned out to be my "Mean Green" alternator wasnt so very mean after all, so the old OEM unit goes back in for now.
Old Jan 8, 2010 | 09:15 AM
2stroke's Avatar
it helps if we know what truck u drive.
Old Jan 8, 2010 | 09:24 AM
benboonie's Avatar
From: Then, raised central PA; Now where ever Uncle Sam sends me.
Acting?
How was your alternator acting before it went out? On start up my gauge will fluxuate badly until it has ran awhile. Anyone else have this problem?
Ben
Old Jan 8, 2010 | 04:45 PM
Paco98's Avatar
Ben Boonie yes I have, had your checked your battaries.
Old Jan 8, 2010 | 06:24 PM
patdaly's Avatar
This will get you started, what year 1st gen?
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Jan 9, 2010 | 09:19 AM
benboonie's Avatar
Preheater
Another post more accurately described my issue. Come to find out that mine is the Preheater cycling prior to warmup. The way mine goes is the same as was described as when the engine is cycling to preheat, as that is the only time that is does it, cold cold starts.
Thanks Ben
Old Jan 10, 2010 | 05:38 AM
You are better off posting any 1st gen questions in the 1st gen section. More traffic in there from people who know your truck.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
MoparMarv
Jan 11, 2011 09:28 AM
Smokin96_12v
Jan 21, 2010 01:06 PM
choppers555
Oct 16, 2007 12:29 PM
