carter pusher problems ...
Old Aug 10, 2007 | 10:28 PM
rossco's Avatar
just installed a carted lift pump .. came with the bd bypass kit kit .. seems like its working but truck wont start ... need advice or help ..please ...
Old Aug 10, 2007 | 10:56 PM
2500Ram's Avatar
Need more info on your truck, fill out your sig using the user CP option top left.
What were your symptoms that lead to the LP change. If your a 2nd gen crack the first 3 injectors to purge the air from the lines. If your a 3rd gen don't.
Good luck.
Old Aug 10, 2007 | 11:16 PM
rossco's Avatar
its a 99 , sorry havent got to the sig yet im fairly new in this forum .. i had low psi but no codes yet ...
Old Aug 10, 2007 | 11:20 PM
rossco's Avatar
does adding that pump require going anything to the tank ? the instructions bd sent me were pretty short .. it said i had to remove the olr lift pump form behind the filter housing,but what i removed was just a block the fuel ran through,not a lp ...
Old Aug 10, 2007 | 11:26 PM
rossco's Avatar
check for fuel at banjo going into the vp, had fuel there ... can here the pump running off and on, first try it fired and died , second time did the same thing ,now it wont start at all ... i have no idea what it is doing ..
Old Aug 11, 2007 | 08:43 AM
Howy's Avatar
Did you try and crack the lines at a couple of the injectors?
When I put my pump in I had to bleed out a couple of the lines right at the valve cover. Once I got fuel there it started right up and ran rough for a few seconds.
Also, are you sure you don't have an in tank pump? If you do, Im not sure how well a pump will pull fuel through it. You may need to get rid of it.
Im no expert but hopefully this helps a little.
Have a good one.
Old Aug 11, 2007 | 09:30 AM
rossco's Avatar
well thanks alot guys .... i will go give cracking the injectors a shot ...
,im sure it has an in tank pump. im still getting fuel up to the vp, i think i just have some serious air in the lines ..
Old Aug 11, 2007 | 09:35 AM
FMB's Avatar
FMB
I changed the order of your quote here;
That is because you have an in-tank lift pump (or other after market pump) installed by/for a previous owner. It seems you are now attempting to have the Carter pull fuel from the tank, through the in-tank lift pump which is more work than it is designed for. Keep that block on the back of the filter, it is needed to feed fuel from your new LP to the filter.
Yeah, in your case it does. You will need to find and pull the lift pump you are attempting to replace and add a dip tube (?). Maybe someone else can help here too, cause if you actually have an in-tank pump, and pull it, then you have to replace that with just the sending unit (tank level) which has the dip tube.
Good Luck, have fun,
Old Aug 11, 2007 | 09:59 AM
rossco's Avatar
i have the carter all installed now , and have cut and removed all lines in front of this pump all the way to the filter... its just a straight fuel line .. i honestly have no experience with in tank pumps ...
Old Aug 11, 2007 | 10:11 AM
rossco's Avatar
so there more than likely is an in tank pump,but when i unpluged the wiring to the old one and plugged it to the new one,would i be ok then if the old one isnt working ?
Old Aug 11, 2007 | 10:58 AM
FMB's Avatar
FMB
I don't think so. Another piece of info that makes me not think so is the fact you can't start your engine. Hopefully, SOMEBODY is out there that has added an aftermarket pump and can tell you for a fact the in-tank pump has to be pulled. Where did you get that pump? Any support there?
Old Aug 11, 2007 | 11:03 AM
qwest's Avatar
OK , there is or is not a Lift pump mounted to the engine behind the fuel filter.
Is this where you removed the plug from ?
If no LP at engine , is there anything in front of the fuel tank. ?
Did you 'kick' the starter a few times to here the lp run and see if fuel comes out at the Inj pump.?
Hard to understand where your at.
Old Aug 11, 2007 | 11:18 AM
rossco's Avatar
no there is no pump i can find anywhere.. so i believe it is in the tank.. the kit i bought is from bd-power,it is the oem bypass lift pump kit... and i did loosen the banjo going into the vp,it had fuel press.
Old Aug 11, 2007 | 11:24 AM
qwest's Avatar
kick the starter, , should here carter run for about 30 sec
than try hooking back up the wire you removed, and repeat process.
should hear tank lp run 30 seconds...If there is one....
And you do need a fuel pressure gage...
Old Aug 11, 2007 | 01:25 PM
rossco's Avatar
i have a gauge its on my edge attitude , i pulled the after market off for now and am going to continue on the factory intank pump til i can find out if i can or cant run this bypass with the stock pump in the tank ... if i can i just have left the area that it goes on the frame clear and all the big line is still in.. so it will be an easy mod now...and you all were right , i cracked th1st and 3rd and bled them and she fired right up thanks evry one .. highly appreciated help, ya all now you sh..
