cant get enough fuel no power plz help
Old Feb 16, 2009 | 10:51 PM
khunter_2007's Avatar
my truck is not getting enough fuel i think
my egts are low no smoke 20 lbs of boost and no power
i changed the lift pump , overflow valve , fuel filter , and took all the lines from my ip to the injectors off and blew compressed air through them and took my injectors out and cleaned them , took dvs out look fine , and checked to see if the fuel plate slid but its fine
i do not have a fuel pressure gauge yet one is on the way but what if the fuel pressure is low what could be wrong or what if the pressure is good what could be wrong
i have no more ideas please help
Old Feb 16, 2009 | 11:14 PM
BigIron70's Avatar
Cummins Guru
Injection pump gear slip? Did you check pump timing ? Check fuel run solenoid on injection pump make sure it is going into full fuel position.
NO: 18-29-95 Rev. A
SUBJECT: Diesel Low Power/Poor Performance
DATE: Oct. 16, 1995
NOTE: THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-29-95 WITH AN EFFECTIVE DATE OF OCT. 16,1995 WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE MARKED WITH **ASTERISKS**
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A CUMMINS DIESEL ENGINE AND AUTOMATIC TRANSMISSION.
SYMPTOM/CONDITION:
Slow acceleration or lack of power with engine at operating temperature.
DIAGNOSIS:
Scheduled maintenance of air filter, fuel filter & strainer and valve lash adjustment must be current prior to performing this Technical Service Bulletin.
Using the chart below, locate the appropriate time for the vehicle being tested.(See Illustration)
With the vehicle in Drive, on dry, flat straight - away of sufficient length. Run at least two 0 - 60 mph tests in opposite directions and record the time in seconds. Average the times and compare to the charted time for the vehicle.
If the measured time exceeds the charted respective time listed for the vehicle, proceed to repair procedure.
If the measured time is less than or equal to the charted time listed for the vehicle, performance is within specifications and no further diagnosis or repair is needed.
REPAIR PROCEDURE:
This bulletin involves testing vehicle performance in three areas (wide open throttle, low pressure fuel system, injection pump timing). Adjustments or repairs will be made based on the results of the tests.
CHECK FOR WIDE OPEN THROTTLE:
The key and engine should be off for this test.
Two people are needed for this test. From inside of the vehicle, press the accelerator pedal to the floor. If throttle lever is operating correctly, the throttle lever to injection pump lever linkage rod should stop moving while the throttle lever continues to move towards the rear of the vehicle.
If adjustment is needed, refer to the 1995 Ram Truck Service Manual (Publication Number 81-370-5108) Group 14, accelerator pedal and throttle rod section.
Additional Automatic Adjustments:
Adjust the throttle valve cable to zero lash at zero throttle position. Refer to the 1995 Ram Truck Service Manual (Publication Number 81-370-5108) Group 21, 42RH/46RH/47RH Transmission in-vehicle service.
With engine ignition on and engine NOT running, adjust throttle position sensor to read 1 volt at zero throttle position. Refer to Group 14, Component Removal/Installation for Diesel Engine.
If adjustments were made, return to Diagnosis section of this Technical Service Bulletin and repeat steps 3 thru 5.
If no adjustments were needed, proceed to low pressure fuel system check.
LOW PRESSURE FUEL SYSTEM CHECK:
With engine off, install Diesel Low Pressure Gage **(Miller Special Tools, Tool Number 6828) and the Fuel Feed Line Connection Adapter (Miller Special Tools, Tool Number 6976),** at fuel feed line injection pump connection.
**The tools can be obtained from Miller Special Tools at 1-800-801-5420 with the tool numbers given below.**
**The Diesel Low Pressure gage can be found in the Miller Special Tools Tool Kit number 6846.
A new kit that includes the gage and adapter, may be ordered by Miller Special Tools, tool number 6977.**
Start engine and let idle. If gage reads 12 psi or more proceed to injection pump timing adjustment section below.
If gage reads less than 12 psi, turn engine off and replace overflow valve in injection pump.
Start engine and let idle, if gage reads 12 psi or more, return to Diagnosis section of this Technical Service Bulletin and repeat steps 3 thru 5.
If gage reading has not changed and is still less than 12 psi, turn engine off and replace the fuel lift pump.
If gage reading has not changed and is still less than 12 psi, refer to Group 14, Diesel Engine - General Diagnosis for further assistance.
If a copper sealing washer is used on the fuel feed line, it must be replaced before reassembly. The rubber sealing washers are reusable and do not need replacement.
INJECTION PUMP TIMING ADJUSTMENT:
To determine the proper timing specification for each vehicle, the CPL number should be referenced. The CPL number is located on the engine data tag, in the middle section, top line (Figure 2).
For 1995 1/2 M.Y. engines equipped with Automatic transmission and a CPL number of 1968, set timing not to exceed 14.5 degrees BTDC static timing or 4.9 mm plunger lift at TDC.
For all other 1994 and 1995 M.Y. engines, set timing not to exceed 13.5 degrees BTDC static timing or 5.9 mm plunger lift at TDC.
Record as received timing. For further assistance with pump timing reference 1995 Ram truck service manual (Publication Number 81-370-5108) Group 14, Diesel Engine - General Diagnosis.
Return to Diagnosis section of this Technical Service Bulletin and repeat steps 3 thru 5. If test time still exceeds the value as listed for subject vehicle, proceed to remove and replace injection pump section below.
REMOVE AND REPLACE INJECTION PUMP:
Remove injection pump and send to Bosch ADS shop for Low Power fueling and timing adjustments.
Install injection pump, check for leaks, road test and return to Diagnosis section of this Technical Service Bulletin and repeat steps 3 thru 5. Record final readings and return vehicle to customer.
Old Feb 17, 2009 | 01:18 PM
dieseldemon's Avatar
I assume it is a 94 engine two areas you don't list one is the fuel heater right beside the lift pump it has a screen inside that could be plugged the hsg unscrews the other place I would look is the screen inside the fuel tank on the bottom of the module
mt250
Dec 4, 2009 10:07 PM
mar67655
Jun 21, 2009 08:30 PM
Boatnik
Aug 5, 2007 09:09 PM
grdnw523
Jan 25, 2006 10:14 AM
storx
Jul 22, 2005 06:12 AM
