Can't get drums off
if you are gonna replace the drums anyway & have access to a welder, weld a little bead between then studs in a few spots.the heat and shrinking from the weld will pop them loose.hook the ground to the drum so you don't damage other thing's with the current & disconnect the batteries.i have used this method quite abit.
I had the same problem with mine when i lost an axle seal. I spray them with a lot of penetrating oil beat the heck out of them and nothin. So i just took the wheels off three days in a row and sprayed them with aerokroil and kept driving around then the fourth day jacked it up and one swing each they popped right off.
I'll give them another shot in the AM with my air hammer and some more penetrating oil. First, though, I'll make sure they're properly adjusted and try to get them to pop off while spinning and applying the brake.
This is really frustrating.
What years did make a full floating axle where the drums come off the hubs?
Interesting... will the hubs interchange with a dually
I watched a small town gas station mechanic beat a full floating drum to death trying to remove the drum without pulling the axle shaft and spindle nut.
Jim
Jim
Firstgenfanatic
12-23-2007 01:14 AM
Pete Miller
15
12-17-2005 01:16 AM
