Can this torque spec be right,,,,crank
Old Mar 16, 2007 | 04:47 PM
Bad Ramer Jamer's Avatar
The manual say's 30#'s,,,plus an additional 60* for the dampner to crank bolt's. That just doesn't seem tight enough. My torque wrench clicked as the motor was coming up on the compression stroke. Just seems too loose. What do you guy's think. Is that a correct spec. Thank's.
Old Mar 16, 2007 | 04:55 PM
79warlock's Avatar
Yes, that additional 60 deg makes a big difference in the torque.
Old Mar 16, 2007 | 05:04 PM
patdaly's Avatar
FWIW, My Cummins re-con manual says 92 Lb/Ft.
Nothing about torque/rotate.
Old Mar 16, 2007 | 05:06 PM
patdaly's Avatar
D'oh, unless the common rail Cummins might take a different torque........
What manual are you using?
Old Mar 16, 2007 | 05:18 PM
79warlock's Avatar
It's out of the factory service manual for an 04.
Bad Ramer Jamer
Mar 7, 2008 01:31 AM
Rauschbo
Jun 22, 2004 05:07 AM
bkay
Oct 16, 2003 02:22 PM
MLR1
Aug 21, 2003 10:09 AM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
