A/C Not working
Old Jun 29, 2005 | 07:12 PM
lungo's Avatar
A/C Not working
I have been searching the site for the codes P PCU and P ECU and have found nothing. Does anyone know what they are and if they have anything to do with my A/C or is it something more serious?? Thanks for the help.
Old Jun 29, 2005 | 07:18 PM
phox_mulder's Avatar
Those codes just mean you have no codes.
If you did, the P ECU would be followed by the code stored in the ECM,
the P PCU would be followed by the code stored in the PCM.
ECM=Engine Control Module
PCM=Primary Control Module
phox
Old Jun 29, 2005 | 07:22 PM
lungo's Avatar
So P done after both codes means nothing??
Old Jun 29, 2005 | 08:51 PM
Yes, it is done retreiving codes.
phox
Old Jun 30, 2005 | 10:02 PM
Glenns 2ed's Avatar
When my sensor on the flywheel quit my a/c didn't work--something bout makes the truck think its not running??-it was a female dog to get too also--glenn
Old Jul 3, 2005 | 09:16 PM
lungo's Avatar
My compressor just keeps kicking in and out. I think it is just low charge.
Old Jul 4, 2005 | 06:54 AM
Smokee's Avatar
Sounds like a low charge or low pressure switch.
Old Jul 4, 2005 | 12:19 PM
2500CTD's Avatar
Just fixed my AC. compressor was doing the same thing as yours. Put a can of sealer and a can of freon. Blows cold now. Also I my vavle on the low pressure line is leaking. So I also found the leak!
Old Jul 6, 2005 | 06:48 PM
lungo's Avatar
Thanks for the info. I am going to vacume it down this weekend and cahrge it, also put sealer in. Hopefully it fixes the problem
Sleigher
May 4, 2017 02:12 PM
southpawslingr1
Jul 9, 2008 08:44 PM
jmon12
Jan 29, 2007 07:50 PM
NHDiesel
Sep 2, 2005 11:23 AM
