bullydog now tranny not working?
hey i have a 06 dodge ram 2500 4x4 CTD and the other day i loaded a bullydog triple dog on this truck and eveything went fine. After the install i get in the truck and start it....It runs fine but no PRNF lights are lighting up on the cluster and tow/haul dosnt work and it seems like the truck is stuck in 2nd gear in maybe limp mode? I tried taking the bullydog back off and eveything possible, loading another bullydog and taking it off and nothing will help this problem. Their is no check engine lights and im not sure what i should do? will bullydog send me a reflash file or will that even work?
thanks for your help
with no prnd21 on the cluster up used the torque management option which might have put the trucks trans in limp mode try taking the battery cables off for about 20 minutes and trying without torque management.That option does not defuel when the trans shifts so a stock trans with die in a few miles I think your computer felt the trans slipping when it shifted and put it into limp mode to save inself
ok ill try taking the battery cables off and see what that does and if not ill call bullydog. but yeah the fist time i installed it i hit yes for that torque managment and i diddnt mean to but i diddnt want to pull it off after it started loading. is their a fuse box on the inside of the truck or just the one under the hood?
Sleigher
May 4, 2017 02:12 PM
LilBigd02
17
Feb 28, 2010 09:22 AM
moparmatt
Aug 12, 2007 06:05 PM
BRUISER
Jul 22, 2006 03:13 PM
Towrig
Jun 28, 2004 08:43 AM
