Brake problem
Old Oct 18, 2006 | 12:09 PM
XLR8R's Avatar
Originally Posted by spyder3634
sorry guys I must have described it wrong. Everything is apart and off the truck. I am trying to put it all back on and the four bolts that hold the wheel bearing on won't thread into the holes. I believe it to be the first couple threads on each bolt, not the actual holes. Sorry for the confusion...
If it's just the first couple of threads on the bolts, either get new bolts or take the right size nut and thread it on the bolts to clean them up enough to start; you can also grind the tip of the bolts to a taper so they'll start cleanly - there's plenty of threads left.
If the bolts threads are really buggered, you can take a swiss file and cut threads by hand if you're careful... of course, it's best if you have an actual tap & die set!
Old Oct 18, 2006 | 02:40 PM
spyder3634's Avatar
alright guys, i played around with it last night and got them to fit! Seems the first few threads were bad but not totally bad and I somehow got them to work. All is good except now when braking hard the truck pulls right...????
Old Oct 18, 2006 | 03:44 PM
gmctd's Avatar
The right front isn't braking as hard as the left front brake - or - the left is braking harder than the right - why?
Caster, camber, and toe - the left brake will pull right, and the right brake will pull left.
Unless your alignment is all messed up, of course.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
