boost gauge flutter?
Old Mar 15, 2004 | 06:09 PM
Green04HO's Avatar
Installed boost gauge about 1 month ago. Worked perfect. Needle very smooth. Started "fluttering" in the higher boost levels about 2 weeks ago. Now gauge "flutters" with any boost over 5. I don't know if this a gauge problem or somthing with the turbo? I used the Geno's boost bolt for the install. Checked connections at gauge and at boost bolt. Can anyone shed some light on this for me?
Thanks
Angelo
Old Mar 15, 2004 | 06:14 PM
cmckinney's Avatar
What brand of gauge? I don't see a flutter but I do hear a pulsation. Common issue. Hope you find the issue.
-CM
Old Mar 15, 2004 | 06:18 PM
Green04HO's Avatar
Sorry the gauge is an Auto Meter Ultra-Lite 0-35 psi
Old Mar 15, 2004 | 07:56 PM
MnTom's Avatar
That sounds like a gauge problem to me. The turbo really can't cause a flutter when it is making boost.
Tom
Old Mar 16, 2004 | 06:18 AM
Smokee's Avatar
Sounds like a bit of a leak or obstruction in the line, since it happens as the boost increases.
Old Mar 16, 2004 | 09:02 AM
SBishop's Avatar
Check you intracooler boots. You might have one leaking.
Old Mar 18, 2004 | 06:22 PM
Amish hauler's Avatar
I over tightened my line at the compression fitting and caused a slight crack in the plastic line that came with my Auto guage. Caused the same symptom. I trimmed it back and didn't tourqe it quite as hard the next time and it has been fine since.
Just what happened to me.
Old Mar 19, 2004 | 09:21 AM
Green04HO's Avatar
Thank you all for the replies. I will check the plastic line. I already checked the
boot conections . I think it's either the gauge or the plastic line. Thanks for all the help.
Old Mar 20, 2004 | 08:52 AM
nickleinonen's Avatar
sounds like a line problem. a small leak. a leak that releases pressure quickly can cause the gauge to responde like that... i was testing a 60psi relief valve at home and it caused the gauge to pulse/fluctuate real bad when it cracked open enough so that the pointer on my test gauge came around to the "0" fast enough to bend the pointer... i was not pleased with that. i should have had a snubber inline with my gauge but i didn't have one handy...
TOM R
Apr 5, 2008 09:18 AM
G1625S
Jul 25, 2006 07:39 AM
latitud_rt
Mar 17, 2006 07:18 AM
Cummnzpowr
Apr 27, 2003 08:50 AM
