Boost fitting - Where does this go?
Old Dec 21, 2003 | 02:23 PM
Toomany Tools's Avatar
My orignial BD Torque Dog apparently lost its program so I exchanged it for a Torque Dog Plus. This one has a 3-position switch and came with a brass fitting I assume to be for the boost system. The instructions list this part in the bill of materials but don't mention it anywhere else. Anyone know where it goes? Thanks. ???
Old Dec 21, 2003 | 07:10 PM
RCW's Avatar
RCW
Re:Boost fitting - Where does this go?
I would anticipate it is for trucks that have an aftermarket turbo like the PDR HX40 installed. Those have a pressure fitting on the compressor snail that controls the wastegate, and you install the bleeder elbow to raise the pressure at which the wastegate opens.
Old Dec 21, 2003 | 08:44 PM
amartinson's Avatar
Sounds like a "boost elbow" that would be used to raise boost pressure on manual trans trucks. That setup would not work for you if you have an auto.
Old Dec 22, 2003 | 10:13 AM
Thanks for the replies. Now another question on this: Why can't the boost elbow be used on a truck with an automatic transmission?
Old Dec 22, 2003 | 10:19 AM
geer's Avatar
I believe it is because on the auto it is hard lined. I know on my 6 speed it is a flex line. I don't know why.
Old Dec 22, 2003 | 11:45 AM
MLR1's Avatar
The elbow will work on your truck. The hardline wastegate didn't get used untill 01.
Old Dec 22, 2003 | 05:56 PM
Bearfoot2's Avatar
I have an auto and use the boost elbow. Now I can get up to 30# boost.
Old Dec 24, 2003 | 08:52 AM
tmiller24's Avatar
Isn't the boost elbow actually a fooler to keep the computer from seeing the higher boost numbers? I thought that the computer would balk at anything more than 20#'s?
Old Dec 24, 2003 | 06:44 PM
MLR1's Avatar
The boost elbow hooks to the compressor side of the turbo and bleeds off pressure to the wastegate. A boost fooler hooks to the map sensor & doctors the signal to the computer to trick it in to thinking it has a lower pressure. Most of the performance boxes have the fooler built in, or you can just buy a fooler.
Old Dec 26, 2003 | 04:42 PM
Thanks for the replies. With your help I figured it out yesterday and now get up to 30 lbs of boost.
b.lee
Nov 27, 2009 08:30 PM
jaredb900rr
May 31, 2008 03:56 PM
moparmatt
Apr 25, 2007 02:13 PM
drolex
Nov 27, 2006 07:07 PM
Mostwanted
Aug 14, 2003 07:43 PM
