BLOCK DRAIN PLUG?
Old Aug 15, 2003 | 11:03 AM
slayerfish's Avatar
BLOCK DRAIN PLUG?
Was hoping someone could help-Im changing coolant and cant find a drain plug anywhere on block.The manuals i have are no help. THANX
Old Aug 15, 2003 | 12:09 PM
Barney's Avatar
Re:BLOCK DRAIN PLUG?
There isn't any drain plug for the Cummins in the Ram.
Some Coolant Changing Info here:
http://www.dodgeram.org/tech/dsl/coo...antifreeze.htm
When you drain the coolant out through the drain valve, just put a piece of plastic tubing on the outlet tube of the valve. Then you can route the coolant into a container, instead of having it splash on everything and make a mess.
Old Aug 15, 2003 | 05:21 PM
slayerfish's Avatar
Thanx man-I kind of came to that conclusion after doing a search. A ten thousand dollar engine and no plug. Who'd a thunk it???
Rancher99
Mar 13, 2011 05:42 PM
klx650a2
Jan 10, 2008 12:08 AM
wooff
May 1, 2003 11:22 AM
cpermd
Oct 28, 2002 02:19 PM
