bio diesel blend
Old Jan 4, 2010 | 08:25 PM
snockerfarm's Avatar
bio diesel blend
I have a 2004 cummins . i got some diesel from a friend,said it contained some bio ,not sure of the percentage.I put in 8 gallons topped off tank. check engine light is on rough idle. pulled fuel filter looked fine, check engine light went off.should i drain the tank . any help or suggestions thanks!
Old Jan 4, 2010 | 11:20 PM
jkitterman's Avatar
pull the codes and post them
Old Jan 5, 2010 | 12:46 AM
tempforce's Avatar
same as above, need to see what codes are showing.
u said that the filter is clean, so i would rule out the normal clogged fuel filter.
usually when someone starts using bio-diesel. it plugs the fuel filter a couple of times.
b-100 bio-diesel is a great cleaner. non toxic so u can use it to clean parts, etc.
cc
Old Jan 5, 2010 | 04:01 PM
pulled code , fuel rail pressure to high
Old Jan 7, 2010 | 06:18 PM
pulled code p0088 fuel rail pressure to high drained tank added new fuel & power service , seems fine. scary moment
Old Jan 7, 2010 | 09:30 PM
jkitterman's Avatar
Do not even mess with unknown diesel in these newer trucks. It is not worth it. Quality diesel only.
justen920
14
May 14, 2009 12:52 PM
ted_pulliam
14
May 3, 2008 02:27 PM
DirtEater
19
Sep 4, 2005 01:26 PM
tfarmer96
May 4, 2005 09:59 AM
doubledodge2003
Mar 7, 2005 07:29 PM
